Old 11-26-2010, 07:50 PM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
center bearing yoke bolt Torque?
I've just put on a new Spicer center bearing and would like to know what torque
the bolt should be?
For the record I eliminated the dust-shields because one would rub on the rubber on the center bearing.
I was thinking it could melt the rubber, so a quick search here suggested these aren't all that necessary with the sealed bearings of today's center bearings.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 11-27-2010, 02:56 AM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: center bearing yoke bolt Torque?
put the yoke back on exactly like it came off, you did mark it.. Right. At least put it bak in time if ou didn't mark it 50-50 shot at being right. Use some locktight and get it about as tight as you can with just a wrench. Be sure when you put the joint in that the rear shaft is timed the way it as when it was ballanced last. You may want to weld in some bracing on that carrier bearing bracket. These carrier bearings have a bad habit of premature failure if the drieshafts haven't been properly ballanced.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 11-27-2010, 10:15 AM   #3
Sport/Truck
Sierra Grande Club
I marked everything after I removed the bolt I scribed a mark to get the yoke on the same spline too.
The carrier bearing looks pretty decent, it has the normal spot welds plus it's welded down the sides- maybe after several complaints about them breaking?.
I'll just used the recommended torque for a 1/2-20 bolt and will call it good.
Old 11-27-2010, 11:01 AM   #4
brad_man_72
the boat guy
nice, I haven't seen any with the welds on the sides yet. We usually put a brace on both sides also. Sounds like you did good.
