shocks
im looking at buying some toxic shocks and was wondering about their shocks for the amount of drop i have. I recently ordered 2" drop hangers and i will have about 6-7 inches of drop in the back. They have shocks for a 0-4 inch drop than a 4-8 inch drop, but the 4-8 inch drop says "flip kit" Does the shock mount in a different spot for the flip kit? Or is it still in the same spot?
I dunno which one to order?
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Re: shocks
you have to buy extended shock brackets.or make your own,i made mine out of 2x3 tubing.
Re: shocks
you need the extension for the flip kit shocks?
Re: shocks
i mis understood what you were saying.no the shocks mount in the same spot there just shorter.get the flip kit shock.i got stock shocks thats why i extended the mounts.sorry
Re: shocks
ok thanks a lot .
Re: shocks
yes the shock extenders i recomend, they will put your shock angles closer to stock angles, without the extenders, then your shocks will be in more of an angle,
your suspension moves up and down, not front to rear. |
| Bookmarks |
