11-26-2010, 08:56 PM | #1 |
will this tranny/TC combo work??
this guy has a SM465 and NP208 for sale, and i have a 350/350 combo. will this combo bolt right up right under my truck, or will there have to be some modification, besides the hole in the hump?
........................ __ ............._______|__\____ ............|_({})______({})] ................(O)..........(O) |
11-26-2010, 09:02 PM | #2 |
Re: will this tranny/TC combo work??
I wouldn't exactly say "bolt-up".You should have posted this in the 4wd message board where such swaps are better known.It's not exactly 67-72 specific.
11-26-2010, 09:09 PM | #3 |
well it kinda is, being that my truck is a 70. im wondering if i will need to shorten up the driveshaft, get different mounts, and the whole thing with the bellhousing.
11-26-2010, 09:15 PM | #4 |
You are looking at a bunch of changes here, not the least of which is an automatic to manual conversion. The SM465 is quite a bit shorter than a TH350, so I'm pretty sure your driveshaft lengths are going to change. What kind of TC do you have now?
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. Last edited by raycow; 11-26-2010 at 09:17 PM. |
11-26-2010, 09:16 PM | #5 |
i have no idea.
11-26-2010, 11:41 PM | #6 |
For a lot more information go to www.coloradok5.com A 350 usually came with a 203 tcase behind it. The 465 or 435 trannies are good and the 208 is an aluminium case that will not take a big hit but usually for most is strong enough. I would go with the 4 speed and a 208 in a minute. If you get a pedal assembly and linkage it is not that bad of a swap. If you do have the 203 tcase i would be glad to get rid of the boat anchor. I am not a fan of a 350 tranny niether. When i ran a 350/3 on the tree /205 setup i got about 3-5 mpg more than a like truck i had the 350/350/203 setup with all else the same. Do not really like the part time kits for a 203 either. The hump i think is different but go with a 2" body lift and should only have to cut 1 hole for the shifter. Again go to ck5 for lots of info.
