Old 11-27-2010, 02:03 PM   #1
evan
evan's Avatar
4x4 warning light question
I'm having trouble with the search function on this board so I hope it's okay to ask.
The 4x4 warning light came on in my 2001 Silverado the other day. At the same time the lights beside the 4x2, 4x4 Hi and 4x4 Lo were flashing as though it were having trouble picking one. It seemed to continue driving fine. I shut it off and started it again and it kept doing it. I re-started it again and everything went back to normal.
Have you guys seen this before? Is it an easy diagnosis or should I take it to a shop? Let me know if you need more info.
Evan B.
evan is offline   Reply With Quote
Old 11-28-2010, 10:41 PM   #2
Olden Days
Living In The Past
Olden Days's Avatar
Re: 4x4 warning light question
simular things have happened with my 02. It seems to do it when on long trips but it always seems to drive fine and the 4 wheel part continues to work (I know cause I would have been stuck if it wasn't.) By the end of the trip it clears up and my mechanics say they cant find any codes that have been set. Go figure?
Olden Days is offline   Reply With Quote
Old 11-29-2010, 12:04 AM   #3
bwood
bwood's Avatar
I read about similar issues being traced back to the 4x4 switch on the dash.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 11-29-2010, 12:11 AM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
It's most likely the dash switch. Mine did what y'all are describing on and off for a couple years. It finally got to where it would come on and stay on a lot. About 3 months ago I ordered a new switch from GMpartsdirect.com, I think it was 45 or 50 bucks shipped, about 5 minutes to change and my Service 4WD light hasn't come on since.
This was a common enough issue, the part was remade. If you pull your part, type in the part # in the website above, it will most likely say, "part # blah blah is no longer available and is replaced with part # blah blah".
Hope that helps. For $50 it's cheaper than having a dealer even look at it
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-07-2010, 04:43 PM   #5
jakeblues652
jakeblues652's Avatar
worst case senario, the sensor in the 4x4 actuator in the t-case is on its way out. happened to a '99 we have and costed us $800 to fix it
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains
Originally Posted by Dan in Pasadena View Post
Did you figure out how to fix it?...I mean with other than a BFH?!
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there
jakeblues652 is offline   Reply With Quote
