Old 11-27-2010, 02:58 PM   #1
chopttop
Junior Member
chopttop's Avatar
Shtbx project
Picked up my '70 C30 w/Franklin Camper on frame, after driving by it, parked next to a farmers barn, for 4 years. Put about $1,700.00 worth of work and a lot of sweat into it and took it to Sturgis 4 years ago. It has been sitting in da shed ever since, drums all the way around makes for not a good stopping experience and I hope to remidy that. Picked up a donor vehicle yesterday, '80 C30,4speed w/granny,6 tires w/good tread and a late 80's 454 w/less than 40,000 miles.
'70 has 350/400, plan on swapping out 350 for 454, keeping the turbo 400, swapping out the front crossmember , dropped spindles/springs and a flip kit in the rear. Also has break booster but may use system out of '80 if possible.
At 40,000 miles don't plan on doing much to 454 but may be motivated, depending on funds, to put rv cam, headers...
Will be asking plenty of questions as I go along, this will be a first project of this magnitude for me. Will go a little slow this Wi. winter because the area that these 2 behoumeths will be in in not heated, I will have to build something around the cabs as I work on them. Thanks in advance.
'71 C10, Choptop/Lowered
'70 C30, w/24' Franklin Motor
'91 9c1 Caprice
'90 Harley FL, 127 Ultima engine w/6 speed, Blk & chrome
chopttop is offline   Reply With Quote
Old 11-27-2010, 03:16 PM   #2
chopttop
Junior Member
chopttop's Avatar
Re: Shtbx project
Out in da sticks internet is v e r y slow right now, 1 pic at a time. Shtbx in for the winter and a picc of the 454.
'91 9c1 Caprice
Old 11-27-2010, 03:17 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Shtbx project
The new truck is going under the camper I take sweet cant wait to see it..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-27-2010, 03:30 PM   #4
chopttop
Junior Member
chopttop's Avatar
Re: Shtbx project
Well, the engine,front crossmember and anything else I can use from the '81 for the '70 and then I will scrap the '81.
'91 9c1 Caprice
Old 11-27-2010, 04:06 PM   #5
chopttop
Junior Member
chopttop's Avatar
Re: Shtbx project
Another pic of the engine. I believe it came out of a municipal cube van, long dip stick, inearlier engine photo ?
'91 9c1 Caprice
Old 11-27-2010, 04:07 PM   #6
Chevy350V8
Semper Fi!!!
Chevy350V8's Avatar
Re: Shtbx project
gotta love a 454!
Brandon...
"IT ONLY TAKES EVERYTHING YOU GOT!!"
Semper Fi
Chevy350V8 is offline   Reply With Quote
Old 11-27-2010, 04:13 PM   #7
chopttop
Junior Member
chopttop's Avatar
Re: Shtbx project
I hope so. had to drive it home, appx 50 miles yesterday, had not been used, other than moving it from 1 spot to another, over the last 2 years. About 10 miles down the road started smelling gas and could watch gauge go down, next stop before my 40.00 in gas disappered I pulled over and gas was spraying out 2 holes in front of fuel pump,hope to get better gas milage in future. lol
'91 9c1 Caprice
Old 11-27-2010, 04:31 PM   #8
VA72C10
VA72C10
VA72C10's Avatar
Re: Shtbx project
wow, glad the gas didn't hit the manifolds.....
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 11-27-2010, 04:52 PM   #9
chopttop
Junior Member
chopttop's Avatar
Re: Shtbx project
I quess right now I am not sure where to start. Both vehicles are in the shed. I have 2 engines to pull, should probable look into getting an engine hoist, and have to swap crossmembers.
Some have said to leave the cross member in the '70 and swap out parts from their.
I quess I should probably start by taking the bumper, radiator, hood and inner and outer fenders off the '70, probably should also advertise the 350 before I get to far in case someone wants to hear it run, get it sold, do the front end, swap in the 454, with whatever I have done to it, and put her back together, or something like that. Sounds like a good half assed plan.
'91 9c1 Caprice
Old 11-28-2010, 10:46 PM   #10
chopttop
Junior Member
chopttop's Avatar
Re: Shtbx project
My donor truck ,10,500Gvweight or something like that, has a corporate dually rear end, is their any reason I would want to put that in my '70 dually ? Thanks
'91 9c1 Caprice
Old 11-28-2010, 10:52 PM   #11
chopttop
Junior Member
chopttop's Avatar
Re: Shtbx project
And it would appear, in one of my engine pics, that I have hydralic brakes on the donor, can that be switched over, without to much hassel , to replac my booster system in the '70 ? Thanks
'91 9c1 Caprice
Old 11-30-2010, 08:24 PM   #12
chopttop
Junior Member
chopttop's Avatar
Re: Shtbx project
Got a little bit done tonight, bumper and grille off.
'91 9c1 Caprice
Old 12-01-2010, 09:51 PM   #13
chopttop
Junior Member
chopttop's Avatar
Re: Shtbx project
Got the hood off today along w/most bolts off of fender and cowl. Goes a little slow when you are working alone.
'91 9c1 Caprice
Old 12-02-2010, 10:13 PM   #14
chopttop
Junior Member
chopttop's Avatar
Re: Shtbx project
Cowl and drivers side fender off, wish it would warm up. lol
'91 9c1 Caprice
Old 12-02-2010, 10:24 PM   #15
71swb4x4
71swb4x4's Avatar
Re: Shtbx project
Sounds like Hydroboost on the brakes. I have a 67 one-ton and a 75 is my donor, the 75 has hydroboost. I plan to move the whole thing over.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 12-02-2010, 11:42 PM   #16
chopttop
Junior Member
chopttop's Avatar
Re: Shtbx project
I have to believe that the'80 hydroboost, have pic of brakes in my first engine pic, is better than the booster in the '70. Good luck on your project.
'91 9c1 Caprice
Old 12-07-2010, 08:43 PM   #17
chopttop
Junior Member
chopttop's Avatar
Re: Shtbx project
Little bit nippy,9 degrees,but no wind out in da shed, heat either. lol Got the inner fender off, little bit each day.
'91 9c1 Caprice
Old 12-26-2010, 07:54 PM   #18
chopttop
Junior Member
chopttop's Avatar
Re: Shtbx project
Got back to her today after being off for a while, got the passenger outer and inner fenders off and pulled the radiator. Will have to pick up at least (1), passenger inner fender, and maybe the passenger outer fender. Noticed the base of the core support was rusted and separating, have a line on one w/battery tray, which is also bad on da shtbx.
'91 9c1 Caprice
