Old 11-28-2010, 01:30 AM   #1
TFWiegs
EZ Wiring harness
Any tips for do's & don'ts before I dive into replacing a wiring harness in a 69?
TFWiegs is offline   Reply With Quote
Old 11-28-2010, 02:01 AM   #2
tonypaul
tonypaul's Avatar
Re: EZ Wiring harness
Did you already buy it? I purchsed a ez harness (all black wires) and it had 3 mistakes in the harness. It didnt have a wiper power, three left turn signals wires, electric fan and the power door lock was on the same fuse. I called their" tech line everyday for 5 days in a row and left messages everytime- never got a call back... I would not recommend EZ harness!!!!!!
tonypaul is offline   Reply With Quote
Old 11-28-2010, 03:11 AM   #3
bigbadchev72
People know me
bigbadchev72's Avatar
I liked mine. Got it on ebay, it was a multi colored wiring harness. Don't get rid of your old harness until you install the new. You will have to re-use some of the old connectors, other than that it is really straight forward. Don't let the wipers screw you up either they have constant power with the key on and switch via the ground
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 11-28-2010, 09:29 AM   #4
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
I've used M&H, FWIW they have top quality harnesses with first rate costumer service.
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 11-28-2010, 10:01 AM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I have used the ez wire and so far so good...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-29-2010, 11:28 AM   #6
TFWiegs
Thanks for the info. This is a multi-colored harness, so hopefully no snafoose. Here we go!
