Old 11-28-2010, 01:52 AM   #1
BIG CHEVY 3600
BIG CHEVY 3600 LONGBOX
BIG CHEVY 3600's Avatar
Looking for answers on cooling fans
I had planned on using my mechanical fan but my 350 sits too close to the radiator. That means I'll need a fan. It's a Walker and is 20 inches wide. I was figuring on a single fan. Can anyone give me some suggestions as to what fan and assorted attachments and where to get them. I should have already researched this after 4 years building this 51 but I had not thought I would need it.
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax.
Abraham Lincoln
http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20
BIG CHEVY 3600 is offline   Reply With Quote
Old 11-28-2010, 04:31 PM   #2
sgtusmc
sgtusmc's Avatar
Re: Looking for answers on cooling fans
Are you asking about an electric fan? If so, look for a F@rd Taurus fan (with a V6, 2 speed) it pushes more CFM's than a lot of high $ aftermarket fans. They can be had for little on Ebay or pull-your-part places. I have one now on my 53. I've used them on trail rigs in the past with great luck. I think I have a pic of my setup on my 53 build. If your looking for a mechanical fan please disregard and carry on.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 11-28-2010, 04:36 PM   #3
BIG CHEVY 3600
Are you talking about a 6 volt fan? My truck is 12 volt.
Abraham Lincoln
Old 11-28-2010, 04:57 PM   #4
sgtusmc
sgtusmc's Avatar
No, I'm talking about a 12 volt fan out of a v6 engine F@rd Taurus. The fan is a 2 speed. Awesome fans IMHO.
Old 11-29-2010, 04:45 PM   #5
BIG CHEVY 3600
Sarge,
What year range of Tarus? Will it cool a 350 sbc,330 horse?
Abraham Lincoln
Old 11-29-2010, 09:14 PM   #6
Richard H.
Spanked once
Richard H.'s Avatar
I had to move my radiator forward ,its a 3 core and change the mounting brackets on the fan and radiator. It does not ty-rap to the radiator. Mine is a 300 hp with air. Just showing you how close it is.
The ole 350 budget build.
Richard H. is offline   Reply With Quote
Old 11-29-2010, 10:14 PM   #7
ratrodmiller
ratrodmiller's Avatar
ratrodmiller is offline   Reply With Quote
Old 11-29-2010, 10:18 PM   #8
ratrodmiller
I used a v6 mustang electric fan .I had to chop down the factory fan shroud and fab up my own in faberglass, works great pulls a ton of air too.cools my 5.3 no prob.
Old 11-29-2010, 10:19 PM   #9
sgtusmc
sgtusmc's Avatar
You'd be looking for something like this. Stay away from the duel setup. I've had great luck with these. Do a google search on the fan. Guy's use them on all kinds of rigs, make sure it comes with the connector.
http://cgi.ebay.com/ebaymotors/LINCO...Q5fAccessories
Old 11-30-2010, 09:35 AM   #10
MrDude_1
almost any 90s V8 car with a large single electric fan will work perfectly fine.
so you can look in everything from big Lincolns to 305 TBI Camaros... also some V6 sedans had huge fans, like the Taurus mentioned.
MrDude_1 is offline   Reply With Quote
Old 11-30-2010, 01:29 PM   #11
dwcsr
Hollister Road Co.
dwcsr's Avatar
If your to close for a mechanical fan you will never get a Taurus fan in there and you can't make a Taurus a pusher.
dwcsr is offline   Reply With Quote
Old 11-30-2010, 04:06 PM   #12
BIG CHEVY 3600
Dave
According to the seller (Ebay) the width is 5". I believe with the mechanical fan its 2' shim removed there should be enough room. I will certainly check it out before buying. Thanks for the heads up.
Abraham Lincoln
Old 11-30-2010, 11:20 PM   #13
nebdrummer
nebdrummer's Avatar
its been a while since ive measured my radiator, but on the 38' were working on, we used 2 of the slim 10" jegs fans. 2.5" from mounting to depth of the fan. they have a few other sizes too, but something to think about. and at 50 bucks a pop, its hard to beat.
i used a 14" flex-lite metal blade electric with no shroud thats only a tad over 3" that i cant seem to find on the internet. but it keeps my 400+hp cool no problem. but i will be upgrading to a dual setup with a shroud
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit!
http://67-72chevytrucks.com/vboard/s...d.php?t=380212
nebdrummer is offline   Reply With Quote
Old 11-30-2010, 11:36 PM   #14
BIG CHEVY 3600
I bought the Taurus fan on Ebay. I'll have to do a little fabrication to make it fit but it should work ok. Thanks for all the suggestions guys.
Abraham Lincoln
Old 12-01-2010, 05:53 AM   #15
Arkansas50's
Arkansas50's's Avatar
I see you already bought one. But incase someone else need one, a Mercury Mistique uses the same fan.
1950 Chevy 3600
1951 Chevy 3100
1954 Chevy 3100
1954 Chevy 6400
Arkansas50's is offline   Reply With Quote
