Old 11-28-2010, 10:21 AM   #1
erock805
erock805's Avatar
30 ohm or 90 ohm gas gauge
Can you test this? Trying to sort out my gas gauge issue. I have from what i can tell a square (74 to 87) sub tank. (looked at pictures at the part store) A big one. struggling on getting them working together.
I have two gauges that I tried both read all full when hooked up. yes its heavily grounded.
"Do what you want to the girl, but leave me alone!"
erock805 is offline   Reply With Quote
Old 11-28-2010, 10:24 AM   #2
msgross
msgross's Avatar
Re: 30 ohm or 90 ohm gas gauge
I "think" 67 and newer are 90 ohm... 30 ohm for older trucks...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-28-2010, 11:28 AM   #3
'63GENIII
'63GENIII's Avatar
Not sure if you have the sender out, but if you do you can put an ohmeter on it and run it through it's full range. At one end of the cycle, you will see either 30 or 90 ohms. Pretty easy to convert to 30 from 90 if needed.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 11-29-2010, 08:37 AM   #4
erock805
erock805's Avatar
Like msgross said it seems to be a different ohm rating. I found one guy that put in the older resister on his new tank and that worked.
Old 02-20-2011, 09:42 AM   #5
erock805
erock805's Avatar
found some info on adding a 50ohm potentiometer inline...headed to Radio shack when the open...would love for my gas gauge to actually work!
Old 02-22-2011, 03:58 PM   #6
jimmillac
If you are trying to use an old guage that is looking for a 30 ohm sender, and have a tank with a 90 ohm sender, you will want to connect a 50 ohm resistor in parallel with the 90 ohm sender. That is, one end of the resistor will go to the same terminal as your gas guage wire, and the other end of the resistor will go to ground. You will want to get a 50 ohm resistor with a wattage rating of 3 watts or bigger. I would also recommend you mount it away from the fuel tank because it is going to get warm.
jimmillac is offline   Reply With Quote
Old 02-22-2011, 09:53 PM   #7
TR65
TR65's Avatar
Check out this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=413579
I run the resistor fix on my truck. Works OK. Just non linear as shown on the graph in the thread.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
