11-28-2010, 10:53 AM | #1 |
Wife pissed, stains in concrete, need help...
So, while completing epic brake overhaul, I managed to spill brake fluid on the front concrete walkway up to the house (right by the front porch and entry door).
Anybody have any ideas on how to remove this oil splotch? Time and money not a concern (except of course for ripping up and replacing) Thanks for any and all advice
During first and only engine rebuild " That O-ring? It's a spare I think, but lets keep it just in case we discover we need it" 1955 Chevy 2nd series, "Mabel" |
11-28-2010, 11:04 AM | #2 |
Re: Wife pissed, stains in concrete, need help...
Foamy Engine Brite (engine degreaser) has worked well for me. Takes a couple of applications and some elbow grease (I know more grease is the last thing you need right now), but it works well for me. I spray and let soak a couple time before I scrub and hit with the water. Pressure washer works well if you have one too!
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
11-28-2010, 11:08 AM | #3 |
I tried a bunch of different chemicals to use as a stripper but in the end some quality time with my pressure washer did the trick.
11-28-2010, 11:16 AM | #4 |
Dollar store oven cleaner followed by purple power degreaser
11-28-2010, 11:23 AM | #5 |
Power wash first to get the majority of residue out (not too much direct pressure because it will dig a hole in the concrete). The swirling turbo nozzle works best. Then start with a 50/50 mix of Muriatic acid (for pools) and let it bubble for a minute then wash it off, but not into your flower bed. If you let it go too long you will have a clean spot. It is a good idea to have some soda ash around to neutralize the acid before washing down. If it is not cutting the oil the try a stronger mix with a Stainless Steel wire brush to agitate. If you are concerned about environmentalist giving you a hassle, then neutralize with soda ash first and suck up in a shop vac and dispose of in the sink in your garage. Sewer gets treated, storm drain does not.
If you do not want to mess with acid then Brake cleaner wil do and ok job to get the stain off the concrete but all it does is lift it out of the pores of the crete, if you don't soak it up right away it will settle again somewhere else. In either case make sure the concrete is watered down first before applying chemicals.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 Last edited by Mike Bradbury; 11-28-2010 at 11:27 AM. |
11-28-2010, 11:25 AM | #6 |
muratic acid if all else fails.
11-28-2010, 12:07 PM | #7 |
Hollister Road Co.
Move the trailer and rebrick the walk
11-28-2010, 12:17 PM | #8 |
just deny that the stain exists... "it's a shadow honey"
second the degreaser followed with muratic acid if that didn't work...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
11-28-2010, 12:48 PM | #9 |
Large diamond ring solves a lot of martial issues.
11-28-2010, 12:56 PM | #10 |
1969 short box
funny but soooooo true lmao
tommy morehouse |
11-28-2010, 01:20 PM | #11 |
I have used muratic acid Many times...it works GREAT.....and cheap...
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
11-28-2010, 01:27 PM | #12 |
Thanks for all the quick responses. Headed outside to deal with the issue now.
11-28-2010, 03:15 PM | #13 |
Coke will remove oil stains from concrete. (The soda kind not the other)
Name: Les ---------------------- Couple 80s Couple 70s One 68 |
11-28-2010, 03:27 PM | #14 |
Lots of good suggestions here but you won't believe how good electronics cleaner (in an aerosol can) is for this. I grabbed a can one time thinking it was carb cleaner and hit a small oil spot in the driveway, it completely dissipated. Now I keep one on hand for fluid spots, a small squirt and sometimes a quick hit with the wire brush and they're gone!
It works I promise!
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
11-28-2010, 04:21 PM | #15 |
hahahaha!!!! I've also had great luck with muratic acid (it can be found at Home Depot or Lowes by the swimming pool stuff)
My build, 53 GMC / S10 swap http://67-72chevytrucks.com/vboard/s...d.php?t=305723 My build, 59 Chevy / 88 fullsize swap http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc U.S. Marines - Certified Counselors to the 72 Virgins Dating Club. |
11-28-2010, 05:51 PM | #16 |
Not too environmentally friendly, but I have had excellent success with carb cleaner.
The Stable: 1952 GMC 1/2 ton, 5-window...Owned since age 16...that was awhile ago! Torn apart and waiting for my boys to get old enough to help me. 1990 Chevy K5, 5.3L, 4L60E, slowly going back together as my dune truck. 1951 Chevy 1/2 ton, 3-window...building to sell. Daily Drivers: 1998 3/4 ton Burb with a 6.5 Turbo Diesel and 1994 1/2 ton Silverado. I grew up in Flint, Michigan so I can't help but to bleed Chevy! |
11-28-2010, 06:02 PM | #17 |
72 CST Blazer 4x4 (Revival in progress) http://67-72chevytrucks.com/vboard/s...d.php?t=430968 |
11-28-2010, 06:18 PM | #18 |
I agree with Maxxd07. When I have an deposit of oil or any other vehicle fluid I lay some kitty litter on the area and pour Coke on it. Give it some time to eat away and the kitty litter to absorb and all I have to do is sweep it up.
1949 GMC Pickup A lack of planning on your part... ...does not constitute and emergency on mine. |
11-28-2010, 06:37 PM | #19 |
11-29-2010, 07:39 PM | #20 |
sunlight powder detergent and water
11-30-2010, 09:32 AM | #21 |
If that is all she is pissed about consider yourself lucky.
Leave the stain in place as it may divert her attentions from something more serious. |
11-30-2010, 09:38 AM | #22 |
Catchy title goes here..
curious to see what he gets it cleaned with. I've never used more than the pressure washer and or bleach on ours.
11-30-2010, 10:11 AM | #23 |
vintage car junkie
Pour grease on the rest of it, stained concrete is in right now!
1950 chevy truck, s10 swap, bagged, v8, 18s My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761 |
11-30-2010, 11:00 AM | #24 |
78K & 79C Jimmys
around the pool on oil marks,I wet area then i use pool clorine and a push broom to work it it in a paste,let it sit.blast it off.but this will leave clean marks so do the whole area,hope it's not too big
around the pool i would normally clean it with just high pressure (wand bout 1 inch off deck)and water. you can remove quite a bit of normal dirt,leaving a good gritty,grippy surface but a few years ago it was covered with a rubber rock,chewed up and coloured rubber trowled like cement and spray nine works to get oil outa cloths.....spray both sides.let sit a bit.wash
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
11-30-2010, 12:59 PM | #25 |
it only hurts once, she'll forgive ya...lol! good luck cleaning
