Old 11-28-2010, 12:07 PM   #1
BAMA JEFF
New Member here with questions on 1970 C30.
Hey everyone.....just registered here, although I've been a reader for quite some time. Love the site and there are definitely some fine old trucks here !!
Anyway, I have a 1970 C30, with some neat features that I've never seen before. I'm told it's all OEM, so I hate to do anything to the truck that I had planned. It has a Rockwell rear end (A63-484) with a 5.83 gear. It also has a plate on the transmission with a PTO shaft, as well as a large reservoir under the passenger side that appears to have been for hydraulic fluid. It is a factory A/C cab and all pieces are still there.....it doesn't work, but it may just need charging up. The trans is a 4 sp manual with granny low.....in 4th gear this thing will only run about 50 MPH....LOL It's a 350 2 bbl that runs great, it's just geared LOW. It also has what appears to be a large drum type brake right behind the trans that the drive shaft attaches to.
If anyone knows about this truck and it's features, please enlighten me.....it's the only one I've ever seen like it !!
BAMA JEFF is offline   Reply With Quote
Old 11-28-2010, 12:18 PM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: New Member here with questions on 1970 C30.
Welcome, and nice looking truck. Can't help you much with your questions, but there are some members here that know that stuff quite well. Someone can probably help you out. Eric
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 11-28-2010, 12:22 PM   #3
I know of one other I have seen for sure.Other than that,not sure if I saw one and didn't realize it.But since I saw that 1st one 20 years ago I haven't seen another until now.It's a heavier weight C/30.The 5 & 10 lug hubs are the give away.If you look in the parts books the axles are described in GVW #s.I believe these are 13,000# w/o checking a book.Basically,these are predecessors to the 3500HDs that were introduced in '92.Your truck also has a breather on the driver's side floor,right?I have a it cab with that,so I believe that was from one of these trucks.Your power brake booster in under the cab.Do you have an under hood cowl picture?That truck is awesome,BTW.I love it!!
Old 11-28-2010, 12:29 PM   #4
BAMA JEFF
Thanks for the info so far guys. I will get some pics of under the hood and under the cab in a few hrs. There is a fluid reservoir on the firewall, but no booster. I will look under the cab when I get more pics in a while.
Old 11-28-2010, 12:39 PM   #5
chopttop
Junior Member
chopttop's Avatar
Nice looking truck, I have a '70 C30 that I am about to start working on, have build thread started, it came from factory as a cab/chassis and then had motorhome installed on frame.
'71 C10, Choptop/Lowered
'70 C30, w/24' Franklin Motor
'91 9c1 Caprice
'90 Harley FL, 127 Ultima engine w/6 speed, Blk & chrome
chopttop is offline   Reply With Quote
Old 11-28-2010, 01:05 PM   #6
The cab I have has a/c,too.I figure that was one fine truck.It was a '69.The one I saw years ago was a GMC.It had something I never saw,the tall bumper guards with rubber strips (71/72) and they were white.The truck was red with white top and trim and cattle racks with pinstripe...like Omaha Standard.It was all cherried out and for sale.I wanted it bad! At the time I had my '70 Custom Camper/30 I put a low-profile Reading utility body on.
Old 11-28-2010, 01:37 PM   #7
BAMA JEFF
here is a pic of the Rockwell and the "brake" bolted right behind the trans.....I guess that's what it is....?????
Old 11-28-2010, 02:37 PM   #8
Yeah,that's the e-brake.The truck is basically a light medium duty.It has medium duty designs on a light duty truck.It would be hard to find,but I believe there's a 2spd set-up for that rear.Could be wrong,but if that's the same third member as larger trucks I believe it's possible.
Old 11-28-2010, 10:13 PM   #9
292farmer
292farmer's Avatar
definitely the e-/parking brake behind the tranny, truthfully not really good for an e brake at least mine aint. the large resevoir is basically a brake booster, i cant say its the exact same one as on the c-40-60's but they have the same set up. its probably a 110 (11,000)rear end though 13,000 is poss. im sure whats your spid say for axle code?
btw thats a very very nice c30, been restored recently?
1972 gmc c25 292/sm465 dana 60 w/5.13s
1973 vw super beetle 1600cc/4spd(baja bug)
1974 chevy c60 351v6/np-540+2 speed eaton rear
2005 chevy cobalt 2.2l
292farmer is offline   Reply With Quote
Old 11-28-2010, 11:05 PM   #10
BAMA JEFF
OK....here's the dilemma. I wanted to lower the truck and put a custom bed on it, covering just the center portion of the bed. Then I planned on adding polished fenders to cover the rear wheel and possibly change the exhaust.
The dilemma is this....I don't like the 19.5 wheels or the way the front wheels are so close in....it has a very narrow stance in the front. To get it like I want it I would have to change a lot of things PLUS I was thinking of trashing the 4 sp and dropping in a 5 sp manual trans.
BUT....I hate to alter it since it's all original....SO....I'm thinking I could sell it and go to work on the other C30 I have. It's not as nice, but it would be easier to work with PLUS it has already been changed up a little here and there.
What to do ??
Old 11-29-2010, 07:48 AM   #11
cam.man67
cam.man67's Avatar
Wow, that's a gorgeous truck. Love the color, hope you have god luck working on it.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline   Reply With Quote
Old 11-30-2010, 01:04 PM   #12
Watwood
Jeff, I did a little research on the old truck. I found another thread that talks about Eaton H110s being a larger 10 lug axle in these old trucks. The H110 stands for 11,000 lb axle, as there are also Eaton H052s and H072s (5200 and 7200 lbs), but folks are saying those are 8 lug and have a removable rear diff cover. Check out this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=361230
Here's a thread I found on Eaton H110s:
http://www.pirate4x4.com/forum/archi.../t-850670.html
and another:
http://www.pirate4x4.com/forum/showthread.php?t=576818
The first pic here is from the first thread I attached above, and the axle was identified as a Eaton H110:
These pics are from the second link I posted and it was identified as a H110, but has a removable rear cover and the 3rd member looks nothing like yours.
Lastly, on the housing along the axle shafts, your housing stayed very square, and if you look at the tubes on those above they go from a square look to circular.
So, I googled "Rockwell A63 Axle" it gave me this page:
http://www.truckpartsinventory.com/i...=2&val=c127_m2
which if you search for "A63" on that page you'll see it parallels that code with a Rockwell SQHD axle. So, I googled "Rockwell SQHD" and got this page:
http://www.worldamerican.com/Catalog.../SQHD_rear.pdf
which lists your ratio (5.83) and the other guy's ratio from the first thread above (6.17), of course those could just be standard ratios, but I think these axles are huge, like heavy duty truck huge.
Lastly, I googled "Rockwell C 103 axle" from the other label on your axle I took a pic of the other day, which got me this thread:
http://coloradok5.com/forums/showthread.php?t=75208
and searching images I found this:
http://cgi.ebay.com/ebaymotors/Rockw...#ht_500wt_1182
which is your 3rd member. So, IMO, Rockwell C103 it is. Your truck has drums on the front and disc brakes on the rear axle, which to me was odd, and this thread mentions having to run 19.5" wheels b/c of the 13.5" disc brakes. It could be original, or it could be off of a GM P truck, as might have similar chassis setups. Honestly I don't know, and I've never found something that had such little information on the intro-webs.
Lastly, we have confirmed some of these trucks were optioned up with the large rear axles, brake booster relocation, driveline e-brake, but the another tidbit that supports this possibly being original is that the speedo is close enough to being correct. I don't know what all is involved in changing a mechanical speedo to read correctly with a significant gear change, as most of the speedo changes I've done involved a laptop computer...
Watwood is offline   Reply With Quote
Old 11-30-2010, 01:29 PM   #13
Chris4x4Gill2
just stopping in to say Hi to my HSV buddies.
Jeff thats a great looking truck, have you decided if your going to keep it?
Chris4x4Gill2 is offline   Reply With Quote
Old 11-30-2010, 05:54 PM   #14
don t. - 72gmc
Originally Posted by BAMA JEFF View Post
What to do ??
1st off.....Very nice looking truck.
JMHO....if its as original as you say it is, I would not touch it, but im an originality nut when it applies. They're only original once.
Disclaimer.....its your truck and if you want to paint it pink and put Mary Kay in block letters across the back, more power to ya (big grin).
Have fun.....don t. .....
don t. - 72gmc is offline   Reply With Quote
Old 11-30-2010, 06:00 PM   #15
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Don't have any answers to your questions, but I wanted to say that is a great looking truck. Also, welcome from Norcal!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 11-30-2010, 08:38 PM   #16
BAMA JEFF
WATWOOD ......Holy Smokes man, you have been doing your homework on this thing !! Thanks a ton for the info and pics. From everything I've gathered I believe it to be stock / OEM equipment, most of which I've never seen before......but we just recently got the bug for the bigger trucks. Up until now everything we've had has been 1/2 tons.
We have definitely decided to sell the one in this thread and work on the C30 wrecker and outfit it as we want....just to look good and pull the big grills to different cooking events. If you want, call me or PM me, about the price......if y'all are still interested.
For everyone else.....Thanks a lot for the compliments. It's a pretty unique old truck that we have decided not to alter in any way. Hopefully we can find it a good home where someone will appreciate it as a well optioned dinosaur
Old 01-13-2011, 02:20 PM   #17
prin
prin's Avatar
woot!
prin is offline   Reply With Quote
