11-28-2010, 03:01 PM | #1 |
Having issue with lug nuts comming loose ? / now I need a new rim..
Front left, drivers side, keeps comming loose. I just put new studs and nuts on this side. torqued to 125. I think the holes are too large on the rims now for sure.. Any how I require a new rim 15 inch rally rim of 6 lug, if you have one and you are in the lower bc ( chilliwack ) area please assist, much appreciated.. Thanks
1972 , 4x4, 383 BOAT puller! |
11-28-2010, 03:19 PM | #2 |
Re: Having issue with lug nuts comming loose ? / now I need a new rim..
I'll send you a pm with some info of a possible wheel source.
11-28-2010, 03:21 PM | #3 |
You need to post this in the parts board. Here is the 67-72 parts board: http://67-72chevytrucks.com/vboard/forumdisplay.php?f=8
The 73-87 parts board may be more appropraite since it's a 73-87 rally wheel. http://67-72chevytrucks.com/vboard/forumdisplay.php?f=5 Did you check car-part.com like I suggested in the first thread you had started? It lists Canada too. It's a great site.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
11-28-2010, 10:39 PM | #4 |
Car-part.com says that A Combined Used Truck Parts 1-604-853-2184 has a couple in Abbotsford and Wasney Automotive LTD. 604-526-4266 in Burnaby has a few. There are MANY others too, those are the first two on the list.
11-28-2010, 10:46 PM | #5 |
its all about the +6 inches
it's most likely the wheel causing the issue.
