11-28-2010, 05:11 PM | #1 |
Alt wiring
I have ben looking around on the net for a while and have not found a good answer to how to wire up the 4 pin 140 amp alternater. Have seen some that say you must use all 4 pins and some that just us 2. Some say if you put power on a certin pin it will instantly distroy the alt. Really dont want to do that at like 200 bucks a piece. Thanks for your help.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
11-28-2010, 08:43 PM | #2 | |
Re: Alt wiring
All Gen III alternator voltage regulators were PCM controlled from the factory. Putting a Resisted ignition voltage (through a light bulb or a resister) to pin B(lamp terminal) should make it charge. Heres some connector veiws with pin locations. |
11-28-2010, 09:47 PM | #3 |
Re: Alt wiring
The alt is off a 05 chevy truck. No connector or wires.
11-28-2010, 10:40 PM | #4 |
Re: Alt wiring
11-28-2010, 11:51 PM | #5 |
Re: Alt wiring
I have found this painless Pigtail. It has a digram. Is it correct?
http://static.summitracing.com/globa...nstruction.pdf
11-29-2010, 06:52 PM | #6 | |
Re: Alt wiring
11-29-2010, 07:23 PM | #7 |
1965 Chevy C10, 2005 4.8L/4l60
Re: Alt wiring
clinebarger,
You need Adobe reader if you dont have it.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
11-30-2010, 12:44 AM | #8 |
BMW & ASE Master Certified
Re: Alt wiring
I have mine wired just like the painless, I used a resistor instead of a light...
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
11-30-2010, 12:48 AM | #9 |
Re: Alt wiring
well that is good i just ordered the painless one.
12-01-2010, 09:04 PM | #10 |
Re: Alt wiring
Yes if are running a Painless engine wiring harness you HAVE TO USE THAT RESISTOR THAT COMES WITH THE PAINLESS PIGTAIL!!! DO NOT USE AN AFTERMARKET UNIVERSAL ONE!!!!! Trust me, i bought a universal pigtail with out that resistor and i went through 5 alt's in 2 years of running my motor setup.
12-01-2010, 10:19 PM | #11 | |
Re: Alt wiring
12-20-2016, 09:40 AM | #12 |
Re: Alt wiring
I know this is a really old thread, but I have a couple of questions. What voltage are you getting out of the alternator with it wired like you are talking about? Does the computer have any control over the alternator? I have a Speartech harness with the 2 wire plug for my 2006 motor. It's supposed to have a resistor in the brown wire as talked about above and I'm getting 13.3-5 V on my voltage gauge with the truck running. Does this seem about right? Thanks,
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
12-20-2016, 06:39 PM | #13 |
Re: Alt wiring
Yes, that seems about right. For those who don't know, you can buy a resister from radio shack and solder in the resister between the alternator an the pcm. I have at least twice with good results. Poops I need to doit on the swap also. Dang, how did forget that.
12-22-2016, 09:42 AM | #14 | |
Re: Alt wiring
12-22-2016, 11:44 AM | #15 | |
Re: Alt wiring
From looking at the chart, it would appear that the voltage simply increases as the PWM duty cycle increases. That's true for the most part, but the GM documentation explains that that 100% duty cycle is for diagnostic purposes and results in a 13.8 V output. Adding a bulb or resistor is generally done by folks running carburetors (they aren't using the factory PCM). The gen III motors up to about '04 are connected directly to the PCM and it handles all the PWM magic. The late gen III stuff ('05, '06, and some '07) incorporated a Generator Battery Control Module (GBCM) which added a layer of confusion because it was a separate module. It's easy to identify the newer alternators because they have a 2 pin regulator instead of 4 pin. There's an option in HP Tuners that is something like "GBCM module" and it can be set to "not fitted". This lets the PCM control the alternator without the input of the GBCM. In case you're wondering why you can't just run the GBCM, it requires the Body Control Module to function. |
12-22-2016, 08:19 PM | #16 |
Re: Alt wiring
i have a carb setup and trying to figure this same situation out. any help would be apperciated
12-23-2016, 12:32 AM | #17 |
Re: Alt wiring
The painless link in post 5 is what i did. I got with the local rebuilder and i said i wanted a single wire from the key through a bulb or resistor. I opted for the "L" terminal with a resistor and the "I" terminal is a short wire that goes onto the alternator stud that is wired hot all the time to the battery positive terminal.. Not to confuse anyone but some rebuilders modify it internally so the "I" terminal is connected to the stud and they call these alternators a "single wire hookup".
12-25-2016, 01:46 AM | #18 | |
Senior Moment
Re: Alt wiring
Thanks Again Steve
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
12-25-2016, 09:14 AM | #19 |
Re: Alt wiring
What's your voltage reading?
12-25-2016, 10:18 PM | #20 |
Re: Alt wiring
Just to clarify a little further, the AD244 alternators used on the early Gen III engines used a 4 pin regulator. The Painless part linked above works for those regulators as does the bulb/resistor on the “L” terminal to get it to start charging. If you’re using the factory ECM, I’m not exactly sure why you’d want to use a bulb or resistor, but that’s a subject for another thread
The alternator that Rob is asking about has a 2 pin regulator and is used on the Delco DR44 and Bosch alternators on the late Gen III engines (and all the Gen IV engines). This type of regulator only has the “L” and “F” terminals (no “S” or “P”) and is controlled by a PWM signal on the “L” terminal as shown in the table that I attached above. A bulb or resistor attached to the “L” terminal on this type of regulator won’t hurt it, but it won’t accomplish anything either. It will just charge in “fault” mode at its set point of 13.8 volts (which is exactly what it will do if you just leave it disconnected entirely). Here is a good article from ACDelco on the later alternators with 2 pin regulators: https://acdelcotechconnect.com/pdf/imtn_V12I305.pdf After some back and forth about the information above, Rob and I found that ,contrary to what I posted above, the GBCM settings in HP tuners are only available for the Gen IV ECMs and not a Gen III P59 ECM (So you can't "turn off" the GBCM functionality in the programming for Gen III) It’s also worth pointing out that even though late Gen III and all Gen IV charging systems use alternators with 2 pin, PWM controlled regulators, the systems work differently. The ACDelco article doesn’t break it down by engine platform, but “Integrated” regulated voltage control is the type that is used by Gen IV and requires the use of the Body Control Module. The Gen IV ECM uses a battery current sensor to feed data to the the BCM where it does some calculations and then instructs the ECM to generate a PWM signal to the alternator to make it charge at the rate shown in the table above. I don’t think it’s a huge leap to speculate that the reason that it’s possible to turn off the GBCM control in the ECM is because the ECM has the circuitry to generate the appropriate PWM signal to control the alternator. The second type of regulated voltage control is called *stand-alone” and is used by the late Gen III systems (’05, ’06, and early ’07 for truck engines). Stand alone uses a GBCM instead of a current sensor. The GBCM provides the PWM control for the alternator’s regulator. The Gen III ECM is incapable of providing a PWM signal so the only options here are: 1) Leave with the fixed "fault mode" level of charge 2) Wire in the GBCM to mimic the factory setup (no BCM is needed) 3) Change out the regulator in the alternator from a 2 pin to a 4 pin. |
12-26-2016, 02:36 PM | #21 |
Re: Alt wiring
im just confuesed as ever. i need somebody to put into slow people terms haha . so i have a 68 c10 i just put 2005 4.8 in with carb setup. im tring to use the stock altenator on the 4.8. what pigtail do i get and how do i wire it up. im sorry for being a nob. any help and break down without over load of info would be greatly apperciated. thanks again guy.
12-26-2016, 08:36 PM | #22 | |
Re: Alt wiring
12-26-2016, 08:57 PM | #23 |
Re: Alt wiring
if i remeber right it has a 4 pin plug in back of altenator. i'm offshore at moment so cant go look but im almost 100% sure.
12-26-2016, 09:37 PM | #24 |
Re: Alt wiring
If it's 4 pin and you're wiring it up for standalone use with a carb, connect pin "B" of the connector (the same pin is marked "L" on the regulator) to an ignition hot source through a 470 ohm 1/2 watt resistor. Instead of a resistor, use a light bulb if you want a warning light.
12-26-2016, 09:46 PM | #25 |
Re: Alt wiring
so could i use the holley plug
Holley 197-400 and thats it? |
