vortec intake on std heads
Will a vortec intake match up to gen1 heads? I know I need to make new holes for bolts, I was thinking of intake ports and water ports. I have got a set of Brodix spec alu heads and an Edelbrock rpm air-gap laying i my garage, that I would like to give a try on my truck.
67 c10 Short Step 350/th400 daily driver 69 Camaro work in progress ![]() |
Re: vortec intake on std heads
port height is different and you would be prone to a vaccum leak. I remember a manifold early on in the vortec craze that was dual drilled and it had those troubles. Jim
I have heard of it by using large washers under the center intake bolt heads. But I don't think I would personally.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
"the other guy"
vortec heads/intakes dont have holes. only 8 total intake bolts are used
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" ![]() |
