Old 11-28-2010, 09:59 PM   #1
iceman3085
iceman3085's Avatar
moved fuel tank need ideas for filler neck
fabed up an aluminum tank to mount under the bed and removed the stocker from the cab, need some trick ideas on what to do with the hole where the factory neck came through was thinkn about just afixing the factory cap to the hole but lemme know what yall think
iceman3085 is offline   Reply With Quote
Old 11-28-2010, 10:49 PM   #2
Kidd-7
Kidd-7's Avatar
Re: moved fuel tank need ideas for filler neck
I like that idea; planning on doing it myself. Give the look of a factory tank from the outside.
Kidd-7 is offline   Reply With Quote
Old 11-28-2010, 11:38 PM   #3
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I had been considering this vs welding in a plate to cover it up. Seems like it would be easy to do, and seal up too.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-29-2010, 05:10 PM   #4
1970greenc10
1970greenc10's Avatar
has anyone ever tried to plumb pipes from an underbed tank to the stock filler, might look good rather than having 2 filler locations if you don't shave the one on the cab.
My Chevys
79 caprice classic
70 c/10
69 k/10
03 silverado
1970greenc10 is offline   Reply With Quote
Old 11-29-2010, 07:30 PM   #5
hdck07
hdck07's Avatar
1970greenc10, that is an idea that I have been thinking about for when I finally get to build mine. Exhaust pipe welded to the original fill without a gasket and bent down through the floor and back to a tank. I think it would be the best of both worlds.
hdck07 is offline   Reply With Quote
Old 11-29-2010, 08:24 PM   #6
b.eddy's72
b.eddy's72's Avatar
I like covering it up but the coolest thing Ive seen is putting the new filler behind the bedside turn signal on the outside.
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new.
66 GMC Short Step, 84 Front Suspension, many more mods to come
67 Chevy 3/4 Ton, 327, Auto, Factory A/C
Ya must have been movin cause I was haulin a*$ when I passed you
b.eddy's72 is offline   Reply With Quote
Old 11-29-2010, 08:28 PM   #7
BearFlagRepublic
I've thought about doing the same thing myself when I get around to the gas tank. I think the main issue would be with flex, I would guess there would be quite a bit of flex between the upper cab area to the back of the bed. I could be wrong.
I've thought about keeping the filler for aesthetics and adding one behind the sidemarker as well. I think this would give me the best of both worlds also.
BearFlagRepublic is offline   Reply With Quote
Old 11-29-2010, 08:47 PM   #8
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Don't remember who it is, but someone had pix of a toolbox (below-rail height) that contained their fuel tank/cell. Seems as if it also had their air tank and valves for their suspension. I don't have the air ride but putting the tank in a locking box in the bed, essentially close to the OEM location should be an easy putt. If you have a tonneau cover on the bed, nothing would show, but if you didn't, it still wouldn't show unless you're looking into the bed. Spare tire could still be in the original location and/or a hitch receiver. Yeah, I know it isn't very imaginative, but it sure is practical and I like it.
Member Nr. 2770
