hello there........
I've had this truck for about 18 years, the last 6 or so years it sat in the California desert while I was away in China. I just couldn't part with her. I'm back now so she's getting a bit of attention even though she started right up and I drove her home from her desert storage parking spot.
'62 short bed, step side, straight 6 with three on the tree. I bought it from the original owner, Swartz Glass Company on Beverly Blvd, Los Angeles in the early 90's for $300. I've did a bit of work to get her running initially, the cam was eating the distributor gears, so a new cam was installed and I replaced the cracked cylinder head, I found a fresh rebuilt 848 head for $100 and bolted it on, fresh wood in the bed, a reupholster of the bench seat and a couple rust spots cleaned up. Fast forward to today.....I'm going to do some work on the steering box as she wanders a bit under braking and the steering box has a lot of play..........so I'm going the power steering route. The power drums work pretty well but I'm thinking of discs, at least for the front. When I first bought the truck there wasn't much in the aftermarket world now thankfully there is, so it should be that much easier to upgrade some of the factory stuff. I'm sure I'll have some questions. ![]() So here's Rosebud ! ![]() ![]() ![]() ![]() ![]() |
Re: hello there........
welcome aboard !!!! hopefully i have mine as long as youve had yours this is my 1st year owning it
Senior Enthusiast
Welcome to the forum, and back to the States. Thank goodness its been sitting in a desert environment all that time. Should you want to swap in a later coil spring/disc brake suspension the following link may prove helpful:
http://67-72chevytrucks.com/vboard/s...d.php?t=366850 I believe there are also aftermarket kits available to swap discs onto the stock 60-62 spindles if you prefer to keep the original suspension. And post #14 on the attached thread shows the CPP power steering adapter kit for a 1960-62 frame. http://67-72chevytrucks.com/vboard/s...eering+adapter |
Welcome and nice truck.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
#5 | |
That might be a bit above my pay grade ![]() |
60-66 Nut
![]() ![]() Join Date: Mar 2007
![]() Looks like a good solid truck to work with.
welcome! Nice solid ride!
![]() Join Date: Aug 2009
welcome to the board, lots of skill here and lots of nice car guys here to anwser anything, do you have any plans or the truck ?
fellow 62 owner myself |
and a few others
There's a whole "world history" here.
You were in China There's a Texas magnet on the dash And a British flag on the door ![]()
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
Welcome aboard, good to have yet another short stepper. Love the look of your truck
![]() Does the hydroboost still work on the brakes? Last edited by lakeroadster; 11-29-2010 at 04:28 PM. |
#13 |
Everything works except the turn signals don't self cancel
![]() Still running a generator even. The hydroboost works fine, just like power brakes should. The rears lock up really easy and frighten anyone in earshot. I'm changing to power steering because the old manual box is worn out and the truck wanders a bit at freeway speed. The power steering will also help with parking if my wife decides to try and drive it. |
