11-28-2010, 11:34 PM | #1 |
A Question about aftermarket wheels
I have a 72 C20 with a Dana rear and Discs up front.
Right now I have the stock steel wheels 16" I've been looking at slotted aluminum rims 16.5" with a 9.75" rim width. Not sure of the offset.. My question is, will I run into any clearance problems using these rims? J.
1972 Custom Deluxe Highlander C20 1971 Javelin SST New Project 1971 Demon 340 1969 SS El Camino 1968 SS RS 396 Camaro 1967 Barracuda Formula S 1965 140/4sp Corvair Monza Convertible Sorry, but I don't do Fords. |
11-29-2010, 07:09 PM | #2 |
Re: A Question about aftermarket wheels
Maybe I should clarify the question...
Will I have inside clearance issues with the added width of the rim. Will it clear things like the linkage, the sway bar.. etc. J.
11-29-2010, 08:29 PM | #3 |
Between Trucks...
I can't help on the width issue, but you might want to get some prices on 16.5" tires. They are pretty spendy.
Beat it to fit, Paint it to match... |
11-29-2010, 10:13 PM | #4 |
Man of Mini-Talents
I think those will work fine out back, cutting it close on front. Figure backspacing should not exceed 4.5". You should be able to find out the backspacing / offset by going to the manufacturer website.
If I were you, I'd forget the 16.5" and stay at 16 or go to 17's.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
