Hello everyone,
I know there are many options for running lowered suspension on these rigs, but I have some specific questions. I have the 5.9L 12 V Cummins Diesel in my 1970 C/10 with the ST50 turbo. With this motor being a heavier motor stock, what are my options for springs and shocks, spring rates, etc. to properly lower it without bottoming out or basically being non-driveable? I am thinking I will run a 22" wheel and tire, and something along these lines of this drop is what I am interested in: ![]() I am not ruling out airbags, I have seen the dropmember setup, and that is quite impressive...but my challenge is that I still want to be able to use this as a truck if the time is needed (whether it is to tow a car, or a couple of motorcycles). Can you help? Thanks!
Best Regards, Leon 1970 C/10 LWB Cummins Turbo - Build in Progress Many other toys as well... |
Re: Swapped and Need a Drop...
I know you can run bags and a dropmember witha big block, how much heavier is the cummins compared to a 454?
<edit> Just read the 5.9l is 1100lbs, is that right? Damn, that is a big *****.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
![]() Join Date: Jul 2010
First thing to do is get it weighed. then springs and spring rates are easy.
whats wheels are those i really like them??
Thanks robnolimit!
Your truck is amazing! I've seen your work and seen what you do in Auto-X. Big kudos! I will get that info ASAP. As for the wheels, I'm not sure what model they are, but that's the stance/look I'm going for. I want the truck functional as well as aethetically pleasing. Posted via Mobile Device
Happy to be here
![]() Join Date: Mar 2000
For reference, that truck shows the following-
Forza Forged 3-piece wheels... 22*8.5 and 22*11. www.forzaforgedwheels.com 7/9 on 22 CCP 2" spindle, belltech 2" spring, 3" DJM A-arms flip kit, 2" belltech shackle, relocated hangar
#7 | |
Thank you N2Trux - great information!
Best Regards, Leon 1970 C/10 LWB Cummins Turbo - Build in Progress Many other toys as well... Last edited by legendary; 11-29-2010 at 12:12 PM. |
#8 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 11-29-2010 at 01:08 PM. |
#9 | |
#10 | |
(the a-arm pocket is really close to the ground) In the event of a tire failure,... you would be sliding down the road on the a-arm,... make the brakes useless on that side.
we build our cross member to your specs with coil over or air bag hit me up via email or PM and We can get you dialed complete from hub to hub at a killer price!
jonm@scottshotrods.com |
#12 | |
I know I was able to support over a half ton (about 1200lbs I think) in the bed of my '69. I put about 65lbs of air in my rear bags and had it sitting like there was nothing in the bed. Of course I only drove it a few miles and didn't take any high speed corners, but I was running RE6 bags in the rear and they held.
#13 |
Thanks guys. All great information. I will shoot you an email, Jon.
#14 |
Whos truck is that you posted?
#15 |
That truck belongs to a forum member on the c/10 forums named Ctrl-Alt-Elite
#16 |
Cool, Thanks
