Old 11-29-2010, 01:03 AM   #1
jbgroby
jbgroby's Avatar
Exhaust crossover question
I saw this on ebay as a selling point to a 60-66 truck What is the purpose of having a crossover like this is you ran duals?
jbgroby is offline   Reply With Quote
Old 11-29-2010, 02:43 AM   #2
Captainfab
60-66 Nut
Re: Exhaust crossover question
The 'H' pipe like that helps tone down the exhaust noise slightly and is also supposed to help in the scavenging of exhaust gases from the cylinders.
Old 11-29-2010, 02:53 AM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
A couple of years ago I had a new exhaust system installed that duplicated the worn out version, except this time I had them add the H pipe, specifically for noise reduction. The difference was substantial. Without the H pipe the mufflers really barked when the throttle was cracked, now they sound more like a 60's Corvette. The pipe is also credited with building more low end torque, but on a street engine like mine I really couldn't detect any perceivable difference.
Old 11-29-2010, 03:19 AM   #4
Nix62
Nix62's Avatar
That's what I understand happens with twin cylinder motorcycles.......I added an H pipe to a Chinese boxer twin bike I have, did make a bit of a difference in the mid range.
Nix62 is offline   Reply With Quote
Old 11-29-2010, 12:15 PM   #5
jbgroby
jbgroby's Avatar
Ok Thanks I'll look into that also when I "mufflerize". I wonder just how much lowend torque we could possible want with the 305 already, its not like we don't have enough.
Old 11-29-2010, 02:09 PM   #6
vin63
It's Better With Nitro
vin63's Avatar
The H-pipe or crossover pipe was/is mainly used to reduce exhaust noise or drone since it causes turbulence/reduces velocity in the exhaust flow. There are a lot of different theories about its benefits, but like a lot of advertised performance increases, often they are realized at upper RPMs or WOT (which a street driven vehicle does not see that much time). From my experience from countless dyno sessions and flowbench testing, the scavenging affects of an H-pipe or crossover really only happens at WOT for extended periods, such as in oval track racing, etc.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 07-22-2014, 10:33 PM   #7
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I could of just asked my question by starting a new thread.
But instead I typed 'exhaust crossover' and found this thread.
Love these forums.
66 C20 Service Truck:
Old 07-22-2014, 10:55 PM   #8
terbronco7
terbronco7's Avatar
I recently had new exhaust put on mine, at first it was 3 inch true duals with flowmater 50 series, sounded great but I was getting a baffle effect (kinda like going back and forth between pipes, added the h pipe and now more even flow and better sound, as far as performance gains really have not noticed but the sound is better. and no baffle.
terbronco7 is offline   Reply With Quote
Old 07-22-2014, 11:00 PM   #9
'65 chevy lover
This is the main advantage I have heard about along with, increased torque.
'65 chevy lover is offline   Reply With Quote
Old 07-22-2014, 11:19 PM   #10
LostMy65
LostMy65's Avatar
Here is one BadProStreet Post:
Originally Posted by 1Bad62Pro/Street View Post
The h-pipe is used to help equal the back pressure on both sides of the exhaust
The x-pipe is the same but is much better at equalizing the pressure.
There's a big misconception about the intended function of the X-Pipe versus the H-Pipe.
The H-Pipe does balance out the pressures and slightly helps start the scavange effect on the next exhaust pulse. But it's most effective use when properly placed and sized is for it's tuning function. Sound waves enter the tube changing to a specific frequency that was found to be a problem. Prehaps a droaning noise at highway speeds. With the correct placement in the system and correct inside diameter, sound waves entering the tub shift to the problem frequency. When like frequencies collide, they cancel.
The power comes from opening up the exhaust. A slight add comes from the scavenge effect but ultimately the H-pipe is to counter the noise from opening up the exhaust.
The X-Pipe on the other hand is more effective in sound cancellation. By forcing the exhaust streams to collide, some sound frequencies are cancelled. (In a much larger range than the H-Pipe.) You would think the two exhaust paths colliding would cause more backpressure. In reality, the exhaust flow mass follows the path down the same side. (Bending around the inside of the X.)
The sound frequencies cross paths of the exhaust. Cancellation of like frequencies occur even though the mass of the exhaust flow hits and deflects into the same side pipe.
This is all assuming WOT condition or near full mass flow rate. At lower flow rate, the X-pipe does make the low frequency idle sound a little irratic. Something desireable in a Mustang or Corvette. But a Cadillac wouldn't care for it.
This is used as a band aid in tuning high performance vehicles to meet the legal pass-by requirements. Something that is difficult to do on a car like the Viper Roadster or Corvette.
The X-pipe idea was tried on the Viper roadster but ultimately they used the H-pipe design. If you've ever seen the OE system on a Viper Roadster, the exhaust exits the headers, enters an un-Godly hot converter that I have seen damage body panels and melt basalt packing back into a crystal solid. It runs down the side of the car into the main muffler and then to the rear axle. Then it turns to the opposite side and hits the H-pipe which is over the axle and exits out before the axle on the opposite side of the car. If it were not for the Pass-By requirements, this would be an easy design.
Designs like this and the birth of the X-pipe all stem from the need to meet the requirement. Again, the X-pipe just allows the exhaust to be opened up more while tuning out undesireable frequencies. It's ability to "add" power is a debate most drawn up by aftermarket marketing managers. Everyone loves a gadget.
Old 07-23-2014, 08:40 AM   #11
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Exhaust crossover question
Yea Buddy.. LostMy65
X-pipe and H-pipes synchronize the balance of the exhaust pulses from each bank of cylinders based on firing order which increases velocity and scavenging from each cylinder. Most people agree that X-pipes are better at improving performance than H-pipes, especially at the top end. However, H-pipes tend to have a deeper sound than x-pipe equipped vehicles and generally build power down low. These are general claims and your engine and exhaust combination could have different results.
X Pipe vs H Pipe - Summit Racing Quick Flicks
https://www.youtube.com/watch?v=Y0Va3sDhqwI
SVTPerformance.com 2012 Mustang GT - X-Pipe and H-Pipe Test
https://www.youtube.com/watch?v=bU6nZnAgNsI
X-Pipe vs H-Pipe vs Factory Pipe - Ford Mustang V6 - Exhaust Flow Simulation
https://www.youtube.com/watch?v=2crCWF5cmLk
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
