Ground strap?
Where is the braided metal ground strap (behind the driver side cylinder head, from the firewall) supposed to ground to? I remember it being hooked up somewhere prior to my new motor being put in. Thanks.
VA72C10
![]() Join Date: Mar 2008
Re: Ground strap?
I know one went to the frame. I think at the motor mount but could be put anywhere you can put a screw/bolt in.
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
Re: Ground strap?
check out this thread it has all the locations with pictures
http://67-72chevytrucks.com/vboard/s...d.php?t=422234
In some foreign language "merge" means to stop and turn your head left. My build page http://67chev.shawwebspace.ca/ |
Re: Ground strap?
Much appreciated, I favorited that thread. It's the short one that goes to the valve cover
#5 | |
Sierra Grande Club
Re: Ground strap?
![]() s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() Last edited by Sport/Truck; 11-29-2010 at 10:42 PM. |
