11-29-2010, 09:49 PM | #1 |
Wiper Fluid/Washer Questions
Does anyone have a diagram as to how the wiper hosing is set up from the reservoir to the wipers? ANd how it is operated? I figured that I push the knob down to make it work but I could be wrong.
I have a 1970 Chevy C10 P/U |
12-01-2010, 06:50 PM | #2 |
Re: Wiper Fluid/Washer Questions
I have a 70 c10 lwb and I push the knob for the washer fluid, twist it for the wipers.
not that the washer fluid gets too far, I need to find a way to narrow the openings and increase pressure or something, otherwise the fluid doesn't get more than halfway up my windshield unless i'm on the freeway doing 70. I don't have a diagram tho. sorry.
1970 lwb hugger orange. 454 duel fuel cng and gasoline. 1990 Ford F-250 Lariat 2008 Mazda3 |
12-01-2010, 10:32 PM | #3 |
Can't you adjust the washer nozzles to make the fluid go up higher on the windshield?
12-02-2010, 12:33 AM | #4 |
Here kitty kitty kitty
LMC catalog sometimes has diagrams for us to buy specific parts from. These can be helpful to all parts of our rebuild.
12-02-2010, 12:47 AM | #5 |
Thank you for the replies. I truly appreciate it!
12-03-2010, 06:23 PM | #6 |
Did you find your answers?
12-04-2010, 01:41 AM | #7 |
I checked the basic functions but I am thinking that maybe the pump is out. I just need to see a diagram to determine if it is located under the grill where the wiper control rod sits.
12-04-2010, 02:22 AM | #8 |
Old member
The wiper motor and pump are under the dash. The only thing out under the cowl is the moving arms that work the wiper blades.
