Old 11-29-2010, 11:00 PM   #1
SCOTI
SCOTI's Avatar
Control arm shaft hardware
Anyone know where can I find the hardware for the post-73 style control arm shafts? I'm looking for some 'new' freshly plated hardware for my a-arms (just the washers & nuts that keep the shaft bushings in place).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-30-2010, 02:44 AM   #2
stefan
New Member
Re: Control arm shaft hardware
Vernons alignment in Ft Worth will have it and if not Randy will get it or tell you where to get it 817 737 5801
stefan is offline   Reply With Quote
Old 11-30-2010, 01:56 PM   #3
SBTork
Garage wrench
SBTork's Avatar
when I did mine a few months back, I ordered new GM nuts and powdercoated the stock washers.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 11-30-2010, 03:10 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
What about these guys?
http://www.totallystainless.com/
Keith
Convert to disc brakes.
Old 11-30-2010, 03:21 PM   #5
SCOTI
SCOTI's Avatar
1st place I checked but they list complete packages vs independent pieces. I have a catalog I'm going to sort through & see if they break down farther than what the web indicates. I figured it would be worth asking on here to see if there were possibly any 'local' alternatives.
Thanks....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-30-2010, 04:09 PM   #6
lolife99
lolife99's Avatar
My other choice would be these guys:
http://www.gardner-westcott.com/automotive_nuts.htm
http://www.gardner-westcott.com/automotive_washers.htm
Keith
Old 11-30-2010, 07:53 PM   #7
SBTork
Garage wrench
SBTork's Avatar
If it helps...
Nut.....6.69 each PN 9422308
Retainer (washer).....N/A PN 337940
the washers have been discontinued
-Adam
Old 12-01-2010, 11:57 PM   #8
SCOTI
SCOTI's Avatar
I wound up getting some 'shallow' nylock style nuts for the upper a-arms @ Fastenall.
I painted the OE style washers & will add some SS washers behind the nylock nuts to keep things from getting all scratched up (whole chassis is done that way).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
