Gettin It One Pice At A Time
factory oil cooler?
Has anyone have or seen a factory oil cooler? I have one and it seems to be factory. just never read anything here about factory oil coolers.
RIP ELJAY ![]() ![]() Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
Re: factory oil cooler?
I had one on my suburban before I swapped motors. They were a dealer add on option for our trucks - not a factory option.
Pretty simple design. Just an adapter plate between your oil filter and the filter boss on your block that has a thermostat in it that allows oil to flow through the lines to the cooler and back again. Really only necessary if you drive the truck looong distances or tow alot in a hot environment, all it effectively does is add to the capacity of the oil system, keep oil temps lower, and extend oil change intervals by a little bit. |
was on some 6.2 dsl from factory
on all military m1008 m1005 pickups and blazers in radiator with 6.2 dsl
1970 CHEVY MONTE CARLO NHRA/IHRA STOCKER 1976 PONTIAC GRAND PRIX ORIGINAL EXCEPT INTAKE AND CARB 1979 3/4 TON CAMPER SPEICIAL PROJECT |
Ah! huh! cool! dealer option. I definitely want to keep in on my truck throughout the swap. Not going to hurt anything and thats how the truck came. You can see the lines on the lower right of pic.
Yes, my Mil CUCV M1009 with 6.2 has one built in the radiator as did the 87 Crew I'm using for the donor parts.
03 Suburban Z71 Z71 98 GMC Yukon SLT 4x4 Yukon 86 M1009 CUCV Project Milverado 48 Willys CJ2A 48CJ2A |
My 1983 C20 454 granny 4 spd has factory oil cooler - not a bad option for hot AZ, plus this was ordered as a camper special. It also has a stock 7 quart oil pan, so it can use the extra cooling.
I had an 84 3/4t that was a 350, 408 when I got it, had the factory oil cooler on it. I'm sure my 89 crew has it too, but since I didn't pull the motor, not sure. Lines aren't there, but probly went with the motor.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
Definitely available as a factory option ...RPO KC4
Popular with the trailer tow/camper units The lines leaked after a while so they were often disconnected. Also available as a dealer kit;a nos one sold on ebay last week |
Garage wrench
100% accurate. You can call your local parts store for oil cooler, lines, etc. They were definitely a factory option.
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
Sorry for the misinformation then, thought that they were only a dealer option. I took mine out since I swapped motors and I didn't want the gunk from the old coller messing up my new motor.
Anyone know where to get replacement parts for them - I have everything just need a new cooler. Thanks |
is this what your talking about, i have the kc4 rpo code
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
I have a htread asking about some pix of how it is installed. Bough a factory one 2 weeks ago, my 78 came with one but was missing when I bought it.
I have the complete unit except it seems , from your pix, the brackets for the lines and cooler itself. If possible , no hurry or anything could you post or email me some pix of how the lines are run, any brackets for them and where and how the cooler is mounted. The adapter no problem there. Thanks, Steve SCJKOVACH@GMAIL.COM |
#13 |
whoops, plus are those lines for the P/S cooler? pix of those would be cool too. If I can't find one I could bend one up. I am in the process of getting and nstalling all the options my 78 came with from the factory and not there when I bought it.
Thanks again, Steve |
#14 |
My 75 has an oil cooler that sits in front of the radiator. Can't remember if its on the SPID in the glove box, or if its something the PO added.
1975 Chevy Cheyenne w/ v8 350 and TH350 Siverado interior Fleetside bed aka "The Beast" aka "Cheyerado" |
#15 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#16 |
I have an 86 with the factory oil cooler option. My lines are leaking and I can't find new ones anywhere. Has anyone bought these lines and if so, where?
#17 |
Not sure if someone thought mine was a power steering cooler it isn't its the oil cooler, the lines go right in by the oil filter also have the kc4 option
