Old 11-30-2010, 03:20 PM   #1
awc7772000
awc7772000's Avatar
climate control system question
does anyone make a replacement vacuum line set for the a/c controls that plugs into the vacuum valve control
awc7772000 is offline   Reply With Quote
Old 11-30-2010, 03:45 PM   #2
awc7772000
awc7772000's Avatar
Re: climate control system question
anyone please? cause im up crap creek without a paddle without 1
Old 11-30-2010, 04:22 PM   #3
tucsonjwt
When I was rebuilding my vacuum system I could not find those hoses. Mine have a special connecting end molded into the hose (the way it looks, anyway.) You can search for small I.D. hose which should work on the net - I don't remember where I found it. Use your calipers to get an accurate dimension. I ended up reusing my original ones, since they held up pretty well even in AZ heat because they were protected under the dash. Good luck.
tucsonjwt is offline   Reply With Quote
