Old 11-30-2010, 05:52 PM   #1
67mbsc
3spd vs. 350 length
If I change from a 3 speed stick trans, to a TH350, is the drive shaft the same or what are the differences?
2% Forever!!!!!!
67mbsc is offline   Reply With Quote
Old 11-30-2010, 05:53 PM   #2
Tim Christian
Tim Christian's Avatar
Re: 3spd vs. 350 length
Long as you use a 350 turbo with a 6in tailshaft it will be the same
Tim Christian is offline   Reply With Quote
Old 12-01-2010, 10:24 AM   #3
67mbsc
Thank You, Tim. Is the TH350 crossmember easy to find?
2% Forever!!!!!!
Old 12-01-2010, 02:09 PM   #4
Tim Christian
Someone on the board should be able to help you with a factory crossmember the holes are already in your frame and you can get a new rubber mount for it at NAPA
