Dual Battery
How do you wire up two battery so they both will charge?Thanks Tony
1991 GMC K2500 4X4 350/auto 1991 Chevy S10 ext cab. 1990 Chevy S10 1993 Chevy S10 Blazer 4dr 4.3 Vortex/Auto |
Re: Dual Battery
Never done it, but from what I know you need an isolator. It will keep current from flowing between the 2 batteries, but yet allow current from the alternator to flow to both batteries and charge them. Fond this website real quick: http://www.bcae1.com/battiso.htm
Re: Dual Battery
Just hook the second battery up in parallel to the first battery. Red to Red, Black to Black.
Re: Dual Battery
Re: Dual Battery
![]() Join Date: Oct 2010
Re: Dual Battery
The last one I connected I used a solenoid activated with a wire hot with the ignition.
The starting battery would not drain while I went camping. |
#7 | |
It's Better With Nitro
Re: Dual Battery
The trunk of my Super Gas car... ![]()
Re: Dual Battery
If you would be using both batteries to power everything there would be no need to isolate them. Normally though, people would do this for camping or stereo applications, in that case you would want to isolate them, using a deep cycle to power lights, etc for camping or just the stereo system. Then play it all night and still start the truck in the morning.
Re: Dual Battery
You have to decide on your needs, yes it's as easy as black to black and red to red.
But .... if one is dead or craps out, both are. both being charged at same time and discharged. The isolators allows one battery to die ,while the other one stays charged. (100+ dollars for this setup.) Or get a A/B /both/off marine switch and wire it up as you manually select it. Done on boats all the time. (hassle on a car due to popping the hood everytime) One rule with a A/B switch never turn it to the OFF position with the engine running, it can damage the alternator. http://continuouswave.com/whaler/ref...alBattery.html |
Re: Dual Battery
You might be able to score an isolator from a motorhome at a bone yard. Long shot, but will be cheaper than $100.
Re: Dual Battery
I need the second battery (i guess)for my winch.Or will one battery run it?
![]() Join Date: Jan 2001
Re: Dual Battery
I run three batteries with my truck. I have two for the camper and one for the truck itself...all Ultima yellow tops. I am using a 130A alternator (CS144) and an isolator. The isolator is the best since it will, as the name implies, "isolate" the battery by charge demand. It is easier on the system and gives the fullest charge rate to the battery that needs it the most.
I have completely rewired the truck so it can make use of the increased amperage but it was the best mod I could have done as I am using ALOT of ancillary electronics! Bud Last edited by 69sixpackbee; 12-01-2010 at 05:46 PM. |
#13 |
Re: Dual Battery
get an isolator , they are cheap.. no need to spend 100+
every ford oil burner has one under the hood , and there are tons in the junkyards also it takes longer to rechange two battery's without the isolator. and the two batteries tied together kills alt. all things big rigs don't have an issue with.. when they are started they are on for hours, not something that happens in a hobby truck all the time.. |
#14 |
Re: Dual Battery
What are you guys calling a isolator?Can someone post a pic of one.Thanks
#15 |
Re: Dual Battery
As for the demand for the winch, I have seen big discussions on if and when a 2nd is really needed.
Most winches ask or recommend not using them for any length of time. Most times getting stuck it might be 1 min or 2. If you were winching yourself up a rock course for compettion mins count, then I can see having 2 batteries. Since mine is only used for recovery (and most people) one suffices. I guess I was off on the cost, heres an isolator for 50. http://www.jcwhitney.com/2-battery-s...ilterid=c926j1 Last edited by 71blazerdetroit; 12-01-2010 at 07:59 PM. |
#16 |
Re: Dual Battery
Mine is a 8000lbs Warn Winch with 4 solanoids.It on my carhauler
#17 | |
Re: Dual Battery
