computer illiterate
2000 5.3L in a 72 help
what are you using for a throttle cable?
72 2wd blazer 72 swb 4x4 |
Re: 2000 5.3L in a 72 help
Lokar makes a cable for ls engines with cable actuated throttle bodies.
WWW.LOKAR.COM Posted via Mobile Device |
yep, lokar
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
I used the locar on mine also
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 12-01-2010 at 11:26 AM. |
computer illiterate
is there one that looks stock and will snap into a 72 firewall?
![]() Join Date: Apr 2005
You can order their standard cable, which has a black outer casing instead of the braided exterior. I would give them a call to ensure you get the correct cable you're looking for.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
the boat guy
I used the stock ls truck throttle cable. Made a bracket (piece of flat and a 3/8?washer) bolted to the back fuel rail bolt. Then welded a washer to my stock 67 pedal linkage. Cut a slot in both washers for the cabe to slide through then the throttle cale clipped right in.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
a stock 2000 chevy truck throttle cable with a 5.3 is a direct fit for a 72 chevy truck.
