Old 12-01-2010, 11:40 AM   #1
Hazieview
Building Dreams out of Dimes!
Will this radiator work for my '81 with a small block chevy?
Spectra Premium Ind/RadiatorFor your 1981 Chevrolet Truck C10 1/2 ton P/U 2WD 5.7L 4BL 8cylPart Number:
433730
Price:$162.99
AVAILABILITY:STORE PICK UP SPECIAL ORDERVisit your local store to special order.SHIP TO HOMEAVAILABLEShips within 2 business days.Features & Benefits
Built to meet or exceed all OE specifications. Validated for fit, form, and function.
Part Number: 433730
Weight: 25.6 lbs
Warranty: Limited Lifetime
Notes: Heavy duty cooling2 rows, 28 1/4" x 19" x 2 1/2" core size
Description: Radiator
Core Type: Aluminum
Tank Material: Plastic
Number of Rows: 2
Core Size: 28 1/4 in. x 19 in. x 2 1/2 in.
Inlet Header: 3 1/2 in. x 20 7/8 in.
Outlet Header: 3 1/2 in. x 20 7/8 in.
Inlet Diameter: 1 5/16 in.
Outlet Diameter: 1 9/16 in.
Engine Oil Cooler: None
Transmission Oil Cooler: 8 1/2 in. (5 plate)
Shipping Information: Overnight and Two Day shipping are not available for PO Box, APO/FPO/DPO or US Territory addresses.
Hazieview is offline   Reply With Quote
Old 12-01-2010, 01:08 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Will this radiator work for my '81 with a small block chevy?
Yes. Why not install a bb radiator? You can easily change the mounting bracket and rubber bushings.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 12-03-2010, 11:18 AM   #3
Hazieview
I dont see why I would really need a big block radiator.... I'm going to have to run electric fans anyway but if a big block radiator would be better then I would consider it. I'ver heard people mention it but I dont know if I need it you know.
Old 12-03-2010, 12:16 PM   #4
swb85
On a budget like Fred Sanford
swb85's Avatar
That is a big block radiator. Yes it will fit but you need bbc pads & brackets. I run the same rad in my truck and it works good. That is the same part you'll get from any parts shack if you ask for a stock replacement for a big block truck w/heavy duty cooling.....it's the aluminum version of a 4 row copper/brass radiator.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 12-03-2010, 12:44 PM   #5
gchemist
gchemist's Avatar
We live in Texas!! You'll need a BB radiator if you plan to run electric fans. You'll need the biggest fans you can get if you have A/C. Block off the gap between the condensor and radiator. Max air flow is necessary across the condensor for A/C. I run a BB aluminum radiator with dual LS1 fans.
Old 12-03-2010, 12:54 PM   #6
terryj
You might try looking for a 4 core radiator about the same size as the stock one, it will provide more cooling than the 2 core shown in your post. The cost may be a little higher however, in the long run I think it will perform better.
terryj is offline   Reply With Quote
Old 12-03-2010, 01:34 PM   #7
swb85
swb85's Avatar
An aluminum 2 core with 1" tubes will cool more efficiently than a copper/brass 4 core with their smaller tubes.
Old 12-03-2010, 03:34 PM   #8
terryj
Thanks for the information, I'll remember that when it comes time to replace my radiator
Old 12-06-2010, 09:59 AM   #9
Hazieview
It says this radiator is for a 5.7 which is a small block. So is this radiator the same as the big block or something?
Old 12-06-2010, 10:00 AM   #10
Hazieview
What radiator do you run? Where'd you get your fans? Got any pictures? Thanks!
Old 12-06-2010, 10:31 AM   #11
bmchevy1979
bmchevy1979's Avatar
Not a 100 % but if its like 73-80 a 5.7 w/ A/C, Heavy duty cooling is the same rad as your standard big block rad
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 12-06-2010, 10:38 AM   #12
swb85
swb85's Avatar
Not sure on the years either, but that's correct.......some a/c 350's got heavy duty (big block) rads
Old 12-06-2010, 09:42 PM   #13
gchemist
gchemist's Avatar
Here is my setup.
I'll probably remove the LS1 fans next year. I'm upgrading to a Mark VIII or Jeep fan. I plan to use the dual speed fan. Low for A/C and high for cooling. http://www.fordmuscle.com/archives/2...cfan/index.php
I run my engine hot. The ZZ4 aluminum heads like heat. Best performance on MPG is near 195. I run a thermal switch on the fans now. The fans turn on at 205. Turn off at 190. The temps are not great for A/C!! I'm upgrading to a crossflow condensor too.
Old 12-07-2010, 07:27 AM   #14
Hazieview
So I should go with the radiator I picked out I think. Right?
Any suggestions on which fans to get for my particular radiator?
unfortunately autozone is the closest auto part store to me...
