Old 12-01-2010, 03:49 PM   #1
Nix62
Nix62's Avatar
62 w/torsion bars.......sway bar ?
I read the great article by Tx Firefighter on sway bays in the FAQ's.........but no mention of trucks with torsion front ends.
Any mounting issues or continue as per the article ?........ I've already got a junkyard bar
Nix62 is offline   Reply With Quote
Old 12-01-2010, 05:34 PM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: 62 w/torsion bars.......sway bar ?
I wouldnt think so. Just need to make a mounting place on the lower control arms.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 12-01-2010, 06:39 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
I haven’t seen the Tx Firefighter thread, but did find this link on the same topic which clearly shows the method of attachment of the sway bars to the control arms.
http://67-72chevytrucks.com/vboard/s...d.php?t=351586
Years before I swapped to a 1975 front suspension, I installed an old link style Mustang II sway bar on my original 1960 front control arms. The control arm brackets were simple U-bolt shackle plates from a tractor supply house, bolted to the lower flange of the arms. In spite of how the arrangement may have looked, it worked perfectly for many years and made a big improvement in handling.
The forward pivot bushings did not require frame brackets because the links at the control arms aligned the bar properly at normal ride height.
When I installed the coil spring suspension, I bolted the 1975 bar loosely in the control arm brackets, jacket it into position, marked & drilled the frame for the mounting brackets and bolted it all together.
I’ve not seen it done on a torsion bar chassis, but this same process should work fine on the 1960 control arms as well. I would suggest bolting the frame brackets to the bar, jack it into position and align everything on the control arms making sure they are centered. Then simply drill the frame and control arms and assemble.
Old 12-03-2010, 03:39 PM   #4
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: 62 w/torsion bars.......sway bar ?
Mustang II IFS CLIP
Project: "Full Metal Yellow Jacket" Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=321173
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 12-04-2010, 11:00 AM   #5
62gmc910
62gmc910's Avatar
It is not a real good idea to weld or bolt any thing to the front lower A arm flanges, a lot safer to use the "shock'' mount hole and drill another point on the web to anchor the sway bar,
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
