Old 12-01-2010, 06:11 PM   #1
Seafoam72
3 on the tree - trouble shifting
As the winter weather gets here
it becomes harder and harder to get my truck into
1st or Reverse. Pulling back from 2nd and 3rd is impossible when it's cold enough (50degress or so). Probably wont even be albe to drive it to work in the am tomorrow.
If I'm able to get it into gear, and get to work, once I come out for lunch
and the weather has warmed up it seems to work fine.
Totallly dependent upon the temp outside
Oddly, running the truck until it heats up to running temp
does nothing if its cold as hell outside....
What can cause this...?
Seafoam72 is offline   Reply With Quote
Old 12-01-2010, 06:25 PM   #2
burkeens
Re: 3 on the tree - trouble shifting
maybe this will help
http://67-72chevytrucks.com/vboard/s...d.php?t=215307
burkeens is offline   Reply With Quote
Old 12-01-2010, 06:26 PM   #3
raycow
The grease in the column shift mechanism could be getting too stiff because of the low temperature. Try washing it out with solvent and re-lubing with something thinner.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 12-02-2010, 06:50 PM   #4
Seafoam72
Ok, I'll check it out.
Will this require a wheel puller?
Never taken the steering wheel off this truck..
Thanks guys!
Old 12-02-2010, 08:29 PM   #5
raycow
Yes, you will need to get the turn signal switch out of the way so you can get to the shift mechanism.
Ray
Old 12-03-2010, 09:40 AM   #6
ges55
BLACK SATIN
ges55's Avatar
I have taken the shift lever off & sprayed WD40 or equivalent in there & helped mine out alot.
67 C10 Fleetside LWB-283, 3 on the tree,power assisted steering, father-in-law bought it new
67 C20 Fleetside LWB-'85 305 V8 (original was 250 6 cyl), Holley 600 carb, full length Hedman headers, dual exhaust behind the back wheels, 4 spd , manual steering
85 C10 Silverado- 305ci
ges55 is offline   Reply With Quote
Old 12-03-2010, 11:03 AM   #7
Seafoam72
Great.
I'll give it a try Saturday.
Thanks for the advice y'all!
Old 12-05-2010, 06:33 PM   #8
Seafoam72
I pulled it all apart,
and now cannot get it back together properly.
I assembled the turn signal mechanism
but I'm not sure what to do from there...
When I place it over the column
it doesn't seem like it sits right...
and when I put the wheel into place
the column threads don't stick out past the surface of the wheel
What am I doing wrong?
Is there a diagram somewhere that I can reference?
