12-01-2010, 07:08 PM | #1 |
Looking for rear diff info
Is there a thread somewhere that has info on what different rear ends were offered on these trucks? Also, how much power they can handle stock and recommendations on how to beef them up?
Evan B. |
12-01-2010, 10:17 PM | #2 |
Arrived on a Pale Horse
Re: Looking for rear diff info
This may help a little.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
12-01-2010, 10:35 PM | #3 |
hmm so I either have 2.76, 3.07 or 3.73.....
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
12-01-2010, 11:24 PM | #4 |
yeppers ive got 3.73's and a 10 bolt
84 Short bed 350: Hooker headers, flow master 40 series, edelbrock Intake manifold, Holly street avenger carb, 4 inch skyjacker suspension lift, 33x12.5 Toyo Open Country Mud Terrains, 3.73 gears 2011 Silverado LTZ |
12-02-2010, 12:01 AM | #5 |
my 85 c10 swb silverado shows 2.42's for rear end gears according to the glove box label. its a 10 bolt.
12-02-2010, 05:25 PM | #6 |
I'm going to be building one truck out of two. One of them has a 10 bolt and the other has a 12 bolt. Is one stronger or more desirable than the other?
Evan B. |
12-02-2010, 06:11 PM | #7 | |
go with the 12 bolt
1985 c10 355 th350 (working on 4 speed conversion to super t10) 1979 camaro 358 super t10 2003 f250 superchip slp exhaust |
12-02-2010, 06:35 PM | #8 |
Still plays with trucks
Use the 10-bolt.
The truck 12-bolt has a smaller diameter pinion bearing and is weaker than the 8-1/2" 10-bolt. The 10-bolt uses the same pinion diameter as the car 12-bolt. The new body style trucks & SUV's use a larger 30-spline axle in their 8-1/2" 10-bolts so you can easily find 30-spline carriers that will fit into the older 10-bolts as an upgrade to make them nearly as strong as the car 12-bolt. You will need to buy new axles to put the 30-spline carrier into your older axle housing but for less money you can pick up the whole rear end out of the new body style truck instead. It is a little wider than the square body part but that is good as it puts the rear wheels closer to being aligned with the front wheel position. All you have to do is remove the perches and relocate them to the right spot for the square body.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
11-09-2013, 07:46 PM | #9 |
Now my 73' has the dana 44 front but my 12 bolt rear has 3.07 gearing as does the dana front. according to the chart my rear diff should have something else but I removed the cover and counted and it is stamped with the gear numbers. 14 and 43 which is 3.07
11-10-2013, 01:33 PM | #10 |
Base axle will typically not be shown on the SPID (or it will show "GQ1" base axle with no ratio specified).
Optional ratios will show on the SPID, both the RPO code and the noun name (GT4 = 3.73 axle ratio). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
