Old 12-01-2010, 08:10 PM   #1
treagan53
Cool Questions for 66 chevy pickup
I have a lot of questions and hoping someone will be able to help answer some of them. I am new at this so please be patient. First question is what steering column can be used for power steering while I leave the key location on the dash? Also it had a inline 250 motor, 6 cylinder, wanting to switch to a small block, will I need new frame pads or will the old ones work for the motor mount? Anyone have an idea on which would be the best chemical stripper to clean the firewall, or any suggestions? I will be switching to disc brakes and I have stock spindles from a 66, would any other year fit this?
Thanks for any help on these questions I really appreciate it.
Tim Reagan
Will try to post pick later.
treagan53 is offline   Reply With Quote
Old 12-01-2010, 08:15 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Questions for 66 chevy pickup
Welcome to the forum. Here’s a link to information on the disc brake upgrade:
http://67-72chevytrucks.com/vboard/s...d.php?t=367260
Other members know more about the other questions.
Old 12-01-2010, 08:42 PM   #3
jimmydean
jimmydean's Avatar
Your stock steering column will work, you just need a box and pump from another truck plus the box plate adapter from CaptainFab. Power steering is an easy swap.
<edit> I used the box and pump from a '75 when I built my '69. Cheap and parts a plenty.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 12-02-2010, 08:08 AM   #4
treagan53
sorry i should have said the steering now has a 3 on the tree and i am going to a automatic.sorry again i forget to post it.again thanks.tim
Old 12-02-2010, 10:05 AM   #5
Real_McCoy
Real_McCoy's Avatar
First of all, welcome to the forum from SouthCentral Kansas.
With the right fab skills, you can adapt almost any steering column to these trucks, but the most popular seems to be the 73 - 87 Chevy/GMC truck columns. There are a ton of threads with information about this swap on the forum. Use the search function.
I am not familiar with a 256, but then I am not the most experienced builder around. The 230 and 250 I6 motors use the same perches as the 283, 305, 327 and 350. There may be other blocks that can use the same perches as well. These all will bolt up to the same bell housing as well as far as I can tell. Again, all of this is on the forums.
I have no idea about the degreasers/strippers and you already have the thread on the suspension/brake swap so I won't go there.
Again, welcome.
Daniel
66 Chevy C10 LWB
Support our troops!
Real_McCoy is offline   Reply With Quote
Old 12-02-2010, 10:36 AM   #6
ChevySixty6
ChevySixty6's Avatar
I've used the Dollar General store brand of oven cleaner for degreasing. It
works the best. Although i've only used it on the chassis/suspension, and wasn't to worried about it effecting the paint. I think it was a post from this forum awhile ago that said the Dollar General brand worked better than all the other types of cleaners
Members i've met: LiLRed66
ChevySixty6 is offline   Reply With Quote
Old 12-03-2010, 02:51 AM   #7
rbar
rbar's Avatar
When going from an inline to a V8, the clutch linkage has an extra piece that you get rid of and the remainder bolts right to the V8 block. As mentioned, on the motor mounts, an inline six has the same mounts as a V8, but there is just an extra part that reaches to the inline six you can get rid of. I swapped mine and didn't have to make any changes.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 12-03-2010, 08:26 PM   #8
treagan53
thanks for all the replyes was going to yry to get pitcures today and as i was working on the truck the power in the garage went out.hopefully gets fixed tommorow. again thanks for all the info.tim
Old 12-05-2010, 08:54 PM   #9
treagan53
pictures of 66 chevy truck
