Old 12-01-2010, 10:38 PM   #1
Baged72
Baged72's Avatar
How do you hoist your bed off?
I have a cherry picker that reaches out somewhat far, do you guys use angel iron? 2x4's?? What is a good way??
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Baged72 is offline   Reply With Quote
Old 12-01-2010, 10:45 PM   #2
Hubscrub
Cruzin
Hubscrub's Avatar
Re: How do you hoist your bed off?
i have just used straps but next time i think i will build an thing kinda the shape of an H and hook the hook in the middle of it
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 12-01-2010, 11:21 PM   #3
Cdshinne
Cdshinne's Avatar
I have used a cherry picker and it works quite well but the best way is to buy a case of beer and help will come!
1972 K20 lwb
2000 Z71 x-cab
1970 ford f100
Cdshinne is offline   Reply With Quote
Old 12-01-2010, 11:29 PM   #4
Cdshinne
Cdshinne's Avatar
Oh and the way i did it was took a chain and bolted it to the bed rail holes the PO had from a topper, one just infront of the wheel hub and one just behind. It worked out well but it wasn't perfectly balanced.
1972 K20 lwb
2000 Z71 x-cab
1970 ford f100
Old 12-01-2010, 11:29 PM   #5
1LOW4X4
My engine lift wouldnt fit quite to the middle of the bed, so I used copper wire, #12 I had lying around. When doubled up its pretty strong. To the four corners of the bed.
1LOW4X4 is offline   Reply With Quote
Old 12-01-2010, 11:37 PM   #6
Cdshinne
Cdshinne's Avatar
I had to take off a wheel to get the picker centered. forgot to mention that too im alittle off today!
1972 K20 lwb
2000 Z71 x-cab
1970 ford f100
Old 12-01-2010, 11:46 PM   #7
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
A guy on each side
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 12-01-2010, 11:51 PM   #8
Ackattack
Ackattack's Avatar
When I use my engine hoist to lift it in the past, when lifted the side of the bed would just barely hit the ram, so I got a longer piece of 2x2 metal (1/8" wall) drilled a couple of holes to make it about 6" longer, and lifted it that way. Worked great.
I built a 2x4 "H" that hooks under the bed rails to lift from.
Ackattack is offline   Reply With Quote
Old 12-02-2010, 12:21 AM   #9
Baged72
Baged72's Avatar
My bed is fully shaved, no pockets anywhere and just painted, i don't know if the weight of the bed making an H beam might crack the paint from stress under the bed rails? Just making sure....
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Old 12-02-2010, 02:12 AM   #10
Slick67
Sofa King Crazy!!
Slick67's Avatar
Didn't hurt my paint, just put a sponge on the lift angle iron. This is the attachment that I used on my truck, cab and bed was a 1 person job. Here is their website. http://www.spiderpullingmachine.com/...ifterdelux.htm
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 12-02-2010, 02:32 AM   #11
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
I know the pic is dark, but what I did was use 2 2x4's the length of the bed, tucked them under the railing to keep from scratching the paint. I then tied them together with 2 1 1/2 inch square tube cross bars. I used eye hooks near each end, and then ran straps to my cherry picker.
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 12-02-2010, 09:16 AM   #12
hugger6933
Two post lift works great ,makes it a one man job. Works well for cabs as well. Jim
hugger6933 is offline   Reply With Quote
Old 12-02-2010, 10:01 AM   #13
vin63
It's Better With Nitro
vin63's Avatar
Attachment 663480
I use something similar from Combo Carts:http://combo-carts.com/bed_lift.html#Truck_Bed_Lifter
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
