Old 12-02-2010, 12:50 AM   #1
shermro99
Question Dome Light in Cab
1970 Chevy P/U C10
I cannot get the dome light to go on when the doors open. Is this a flaw or am I missing something? I have checked to make sure there was current going to it and I did replace the fuse....what am I missing? Does it take a specific light?
Thank you!
shermro99 is offline   Reply With Quote
Old 12-02-2010, 12:54 AM   #2
ls1nova71
ls1nova71's Avatar
Re: Dome Light in Cab
Does it have pin switches in the door jam? Cheaper trucks didn't have them.
ls1nova71 is offline   Reply With Quote
Old 12-02-2010, 01:08 AM   #3
yob2kanobe
yob2kanobe's Avatar
yep, check the switches on the door. they build up with rust and gunk. replaced mine and everything works like a charm.
yob2kanobe is offline   Reply With Quote
Old 12-02-2010, 07:46 PM   #4
shermro99
Checked the switches on the side dorrs and they push in and bounce out beautifully. I am wondering if I put the right light in. Which one should it be?
Old 12-02-2010, 08:01 PM   #5
sameyrasmea72
sameyrasmea72's Avatar
Does the light come on when you turn it on from the headligh switch? If so then the problem is in the door switches.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 12-02-2010, 08:33 PM   #6
gnstalodz
get an ohmes meter and check the wiring
gnstalodz is offline   Reply With Quote
Old 12-02-2010, 11:36 PM   #7
shermro99
The light does not come on when I turn the headlights on......Last time I checked the wiring, power was going to the dome light.... So maybe I just need to replace the switches??
Old 12-02-2010, 11:41 PM   #8
Hubscrub
Cruzin
Hubscrub's Avatar
are you turning the knob to turn the light on? it don't come on when you pull the switch out like for the headlights just turn the knob
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 12-03-2010, 11:33 AM   #9
Brock
upgrading to an older model
Brock's Avatar
not meaning to be a smart a$$ but is the bulb blown?
68 stepside, short-box, multi-colored (for now)
Brock is offline   Reply With Quote
Old 12-03-2010, 01:54 PM   #10
RPBurris
RPBurris's Avatar
I was looking into my dome light and couldn't get it to work either. I put the voltage meter on it and no power. Come to find out it was screwed into place with the wires clipped. Great job by PO. Maybe start with the obvious. Bulb, voltage....
1969 Chevy K20 Longbed
RPBurris is offline   Reply With Quote
Old 12-03-2010, 06:06 PM   #11
Mayo
Cool Truck
Mayo's Avatar
I never knew they were supposed to come on when you open the doors.
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline   Reply With Quote
Old 12-03-2010, 10:17 PM   #12
americanmusc1e
americanmusc1e's Avatar
mine doesn't. it does not have door switches...... sounds like a good thing to add though
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 12-04-2010, 01:13 AM   #13
BP68
BP68's Avatar
Also, doesn't the light housing ground to the roof/screw hole. If you have power at the bulb and the bulb is not blown, sounds like a ground problem.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 12-04-2010, 01:38 AM   #14
shermro99
Checked all the above and it is not working. I bought a fuze looking bulb that was in there previously but I am not sure that it correct. What sort of bulb does it take?
Old 12-04-2010, 01:43 AM   #15
dash13
Yeah how about some pictures.
dash13 is offline   Reply With Quote
Old 12-04-2010, 10:16 AM   #16
yob2kanobe
yob2kanobe's Avatar
yea, we need pictures of a dome light thats shut off.....
Old 12-04-2010, 11:02 AM   #17
coloradosean2009
coloradosean2009's Avatar
That is called a festoon bulb. The replacement may be blown. You said that you have power to the socket, so it must be the bulb. If you replaced it with an LED bulb, you may have the polarity switched (+ hooked to -) in which case all you will have to do is turn the bulb 180*.
__________________________________________
Sean
1972 C20
2005 4Runner
coloradosean2009 is offline   Reply With Quote
Old 12-04-2010, 04:26 PM   #18
shermro99
Question Re: Dome Light in Cab
Here are the pics of the dome light.
Old 12-04-2010, 04:50 PM   #19
raycow
Using a multimeter or test light, you should see voltage at both ends of the bulb if the bulb and fuse are good.
If you can't turn on the lamp from the headlight switch, ground the white wire at the switch connector. If the lamp lights now, the switch is suspect. If the lamp still doesn't light, you have a break in the white wire at some point. Try the same test at the door switches. The lamp should light when you ground the white wire if the wire is good.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
