Old 12-02-2010, 02:05 AM   #1
greasemonkey71
ok i have alot of questions
ok i just a 71 C10
the truck starts but its a pain in the ass to start cold..
and when i do get it started it will randomly shut off like its not getting enough fuel...and when i put it in drive it sputters if i giv it any mor than half throttle
and it will die when i put it in reverse
what wold cause it to die and sputter when im driving?
its got an edlebrock intake and carb i think 600
the guy i got it from gave me a procomp hei distributor how hard is it to install
and what will i need to modify to make it work?
greasemonkey71 is offline   Reply With Quote
Old 12-02-2010, 02:09 AM   #2
Ackattack
Ackattack's Avatar
Re: ok i have alot of questions
My first thought would be to check the timing. Make sure you're getting vacuum advance.
The HEI shouldn't be hard to install. You need to do a little re-wiring. I'm sure there is an FAQ to walk you through it.
Manual or electric choke? Are you pumping the gas once or twice before you're trying to start it? Is the accelerator pump actually squirting fuel into the front barrels (that's real easy to see if you take off the air cleaner, the accelerator jets are pretty much right on top in the middle and shoot into the front 2 barrels)
Good luck
Ackattack is offline   Reply With Quote
Old 12-02-2010, 02:14 AM   #3
Mike Bradbury
Mike Bradbury's Avatar
Good idea is to change the fuel filters.
HEI is real easy to install
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 12-02-2010, 02:17 AM   #4
greasemonkey71
its an electric choke. i dont pump the gas. just turn the key..some times it takes like a good 15 mins of trying to start it
Old 12-02-2010, 02:22 AM   #5
Ackattack
Ackattack's Avatar
yeah, give the gas pedal 1 or 2 quick pumps all the way to the floor
Old 12-02-2010, 02:32 AM   #6
greasemonkey71
ok il try that tomo morning
...any tips on starting the motor when its cold
Old 12-02-2010, 03:17 AM   #7
68350
68350's Avatar
The hei install is super easy. bring your motor to TDC and pull your old distributor. drop your knew hei in. hopefully everything will line up or you will have to bring it to TDC again and retry installation. make sure it seats all the way down on the manifold. Then you need to run a power wire to your fuse box(just find an open terminal and plug your power wire in. then throw a timing light on and adjust your timing til it is in the optimal range for your engine. Make sure to regap your plugs as well. Try pumping it once completely to the floor and let off, this should set your electric choke and it should start right away. Do you have a fast idle?
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 12-02-2010, 03:30 AM   #8
Mike Bradbury
Make sure that wire is switched with the ignition.
Old 12-02-2010, 04:38 AM   #9
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
Giving your throttle one or two pumps right after you turn the ignition to "on" and before you try to start it will set the choke. It will help a lot with the cold start.
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
Old 12-02-2010, 09:16 AM   #10
cdowns
cdowns's Avatar
if you still have the original points they need to b set for it to run properly// i'd suggest doing that to make sure of the overall running condition of the motor b4 getting any further into it
Old 12-02-2010, 12:02 PM   #11
greasemonkey71
ok.. i tried pumping the gas this morning and it still wouldnt start
its not even that cold
i think it was 48
Old 12-02-2010, 12:50 PM   #12
68350
68350's Avatar
Have you checked your fuel filter and/or fuel pump? Sounds like a lack of gas is making it into the carburetor. If both of those check out, your carb may need to be rebuilt.
Old 12-02-2010, 01:04 PM   #13
greasemonkey71
i will check in a few hours when im off work
Old 12-02-2010, 09:18 PM   #14
greasemonkey71
ok...the truck has a EB 600 carb but idk how to get to the fuel filter
Old 12-02-2010, 09:44 PM   #15
cparman
sharp as a marble
Like CDOWNS said, start with the basics, make sure that the Ignition is set properly. Check the points dwell, and then timing. IF you have a carb with an electric choke, check to see if it is closing down when first started. Make sure that you see a squirt if fuel, and get the choke closed down. HTH
cparman is offline   Reply With Quote
Old 12-02-2010, 10:01 PM   #16
Hubscrub
Cruzin
Hubscrub's Avatar
yes you need to make sure your choke is set correctly and hooked up, cold starts is the reason it's there you can adjust it by turning the black plastic thing that the wires are going to and you should always pump the gas couple times when starting a cold carb engine.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 12-02-2010, 10:22 PM   #17
swamp rat
swamp rat's Avatar
Sometimes i have to pump mine more than twice, so i'll pump the pedal about 3 times and turn it over a bit, stop then pump it 3 times again ect.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-03-2010, 12:32 AM   #18
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
If you're asking the questions that you are, you're definately not as old as I am.
The basics for getting these old trucks to run include getting a book that is applicable, and then reading it.
Edelbrock carburetors have a website and you can get technical info from that site, for free.
Setting the choke is done as folks have said, but you need to make sure it is set correctly. It's an electric choke, you said, but have you checked to be sure that it closes when you set it? Take the air cleaner off when the engine is cold...before you ever crank it. Then, press the accelerator pedal all the way to the floor, once or twice, but still don't try to start it. Look at the choke butterfly. Is it closed? If it isn't, it isn't choked and will be hard to start. To adjust the choke, there's a simple procedure. If you don't know how, I'm not going to try and mislead you. Look at the website. Again, get a manual that tells you how to tune and adjust these engines. If you have not installed the HEI, then it probably is running points/condensor. The easiest way to adjust them (for me) is with a dwell meter. You can set the points with a feeler guage, but I like the dwell meter. If you have one, set the dwell angle to 30 degrees at idle. This assumes that your points and condenser (it's a one-piece unit) is good. Also, check the inside of the distributor cap and the rotor....are they blackened and pitted? That'll make it hard to start/keep running. Vacuum has to be good, too. If you have vacuum hoses that are leaking, it'll be hard to keep running once the choke opens up. It'll open up when the engine is warmed up enough. There may be a choke pull-off that opens the choke. If it isn't working right, that can add to the hard-to-start issues.
One more thing: What about the plugs? Those Edelbrock carbs can run rich. If so, it's possible that the plugs get carbon-fouled with unburned gasoline. That was the case with my old Edelbrock with manual choke. My Q-Jet Edelbrock solved that issue.
Hope I haven't scared you.
Member Nr. 2770
Old 12-03-2010, 12:56 AM   #19
VetteVet
Msgt USAF Ret
VetteVet's Avatar
One thing no one has mentioned is--Do you have a yellow wire running from the starter to the coil on the plus side? This gives you a full 12 volts to the coil for starting.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 12-03-2010, 02:49 AM   #20
greasemonkey71
no actually it was a lot of help
im new to v8's
i started with little 4 bangers in VW's
but i will wait until saturday to do anywork
i dont have a garage anymore so i have to do all my work on base at the auto shop and that place is only open on the weekend
Old 12-03-2010, 03:16 AM   #21
Mike Bradbury
Sounds like instead of trying to pin point the problem, I would just do a complete tune up. New points, plugs, wires, filters, choke, cap & rotor, and timing. If any one of those are fouled or mis adjusted it will run but not great. Since you just got this truck it would be a good idea to start fresh anyway, then you know the history of the components.
Old 12-03-2010, 03:19 AM   #22
greasemonkey71
well i got a new wiring harness for the engine and som lowering springs and i need to replace the gaskets on the pumpkin and the oil pan
so i will fix the timing replace the gaskets and rewire the motor
Old 12-03-2010, 09:34 AM   #23
cdowns
cdowns's Avatar
i'd ferget about changing gaskets and wiring harness and lowering for now
just concentrate on learning how to do a tuneup like everybody has suggested// and find out weather you have a motor in that truck that will run properly
Old 12-03-2010, 01:35 PM   #24
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
One thing I haven't seen suggested (I think) is to check to see if the choke is hooked up to power and grounded. It should have 12V when the key is on, some hook it to the dizzy for power, but if you have a point-type dizzy that only gets about 8-9V in when running. Easiest spot to hook the choke power to is one of the IGN unfused terminals on the fuseblock, make sure it has a fuse inline too (small, like 5 amps). When you hook up your new HEI this is the same spot to hook up for power. Hope this helps out.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 12-04-2010, 06:29 PM   #25
grs
If it is taking 15 minutes to start it. You could burn the starter up. Don't crank it to long , and let the starter cool off.
grs is offline   Reply With Quote
