Old 12-02-2010, 03:43 PM   #1
bravo
bravo's Avatar
towing with air bags
Can I put air bags on my DD truck and still haul my race truck to the track? If so, what air bags do you recommend?
bravo is offline   Reply With Quote
Old 12-02-2010, 05:22 PM   #2
jimmydean
jimmydean's Avatar
Re: towing with air bags
What is your DD?
I used to haul hay in the back of my '69 with a c notched frame and Slam Specialties RE6 bags in the rear. I think the most I did was about 1200lbs and I had about 65lbs of air in the bags. The truck was sitting like nothing was in the bed and it drove well.
There are quite a few tow rigs on here that are bagged.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 12-02-2010, 06:05 PM   #3
bravo
bravo's Avatar
I have a 2006 GMC truck and wanted to air bag it. I'm new to air bags and was curious if it was even possible
Old 12-03-2010, 12:32 AM   #4
SCOTI
SCOTI's Avatar
Yes, it's possible w/the right equipment. Ride Tech offers bolt-in kits to give you an idea of what it takes.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-03-2010, 01:57 AM   #5
tech@scottshotrods
Are you looking at bagging the entire truck or just the rear? You can maintain and in most cases increase tow capacity with an air suspended truck when done right with the proper air spring. That is one of the many benifits to an air suspension is an adjustable spring rate at the fly. If you have any questions feel free to pick my brain.
tech@scottshotrods is offline   Reply With Quote
Old 12-03-2010, 10:51 AM   #6
bravo
bravo's Avatar
I want to bag the entire truck. What air bags do I have to go with?
Old 12-03-2010, 11:40 AM   #7
SCOTI
SCOTI's Avatar
Wanting to change out the rear suspension or ?? It affects your bag choice.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-03-2010, 04:11 PM   #8
bravo
bravo's Avatar
I was looking to building trailing arms in place of the leaf springs and adding a wishbone. Does this help? But still want to haul my 3800# truck to the track..
Old 12-03-2010, 04:20 PM   #9
SCOTI
SCOTI's Avatar
Bags located on the axle = sleeve style. Bags located on a leverage arm (link bar, truck arm, etc...) utilize a dbl convoluted bag. The actual bag needed depends on the vehicle weight, intended use, & available space.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-03-2010, 04:45 PM   #10
dv8customs
dv8customs's Avatar
Bags over the axle is generally prefered when towing.
dv8customs is offline   Reply With Quote
Old 12-03-2010, 05:33 PM   #11
tech@scottshotrods
I would recommend the Firestone F9100s for what you are looking to do...
Old 12-03-2010, 05:57 PM   #12
bravo
bravo's Avatar
so these Firestone F9100s will hold by themselves my 18' dovetail trailer and my 3800# race truck?
