Old 12-02-2010, 05:50 PM   #1
ChopperDr
Power brake conversion problem
I just rolled my 68 LWB out of the shop. I converted to power disc brakes. Pedal is good, stopped good, but a scraping, grinding noise from the rear drum? I didnt mess with the rear any farther than bleeding the brakes after the conversion to the new mc/booster.A fresh rear hose was also installed.
I called CPP, who supplied the booster, they had no idea why it would operate fine before the conversion, and scrape now. The tech there suggested I readjust the rear pads. I was so stoked that I had a high firm pedal when I fired it up, now I'm bummed I have to trouble shoot this noise.
Any ideas?
Chopster
ChopperDr is offline   Reply With Quote
Old 12-02-2010, 10:40 PM   #2
entourageguy
Yellow truck club
entourageguy's Avatar
Re: Power brake conversion problem
Did you pull the drum off to look inside? You said you replaced a hose for the rear. Is it possible the rears were not even working before and with the new hose they now work but maybe with little or no friction material left on the shoe?
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 12-02-2010, 11:41 PM   #3
spike38
spike38's Avatar
Spike
spike38 is offline   Reply With Quote
Old 12-03-2010, 12:37 AM   #4
C10longwb
Yeah just pull it and check it if you replace stuff do it 1 side at a time so you can refernce the other side but there real simple I just advise you to get the spring plyers made to doing drums makes it alot easier a new hardware kit is very enexpsensive but just sounds like something draging a little another quick idea is maybe Jack your truck up and spin the rears and see if you can get it to make the sound you may get a beter perspective on what it is by that
C10longwb is offline   Reply With Quote
Old 12-03-2010, 09:32 AM   #5
ChopperDr
Good suggestions. I'll pull the drum this morning.
I also need to check on the emergency brake. I didn't say before, but I also just put 1.5" blocks in back so the air bag could run at a little higher pressure at ride height. I think there is a possibility the brake cable could be hanging up. We'll see.
Chopzilla
Old 12-03-2010, 02:31 PM   #6
ChopperDr
I'm an idiot. The center support bearing was scraping on itself. It is a little worn, has about a quarter of an inch play in it. I knocked out the rivets on the mount and moved the mount up to the higher set of holes and adjusted the bearing so it wouldn't rub on itself.
The brakes work really well. Now we need to get in for an alignment.
Chop
