Old 03-05-2003, 09:07 PM   #1
smithjp1
smithjp1's Avatar
Front/Rear axle Option Codes
I just looked at mine, and this is what I saw, does anyone have something similar
I have both front and rear axle options on mine
79510AA Positract RR Axle
79501BB Positract Frt Axle
options on my Glove Box
What exactly does that mean, not lockers right?
Is there a List of option codes out there?
1968 4x4 swb
smithjp1 is offline   Reply With Quote
Old 03-06-2003, 10:48 AM   #2
smithjp1
smithjp1's Avatar
Input?
1968 4x4 swb
Old 03-06-2003, 11:20 AM   #3
Dean
Dean's Avatar
You should have positraction on both unless something has been changed. These are not lockers. My posi front end had a metal tag on one of the bolt holes as well. You could jack it up and rotate the tires to see if it still is posi as well.
I think my lockers are listed as "no spin" on glove box, but I don't have one in front of me. They are all the Eaton/Corporate rear end.
Dean is offline   Reply With Quote
Old 03-06-2003, 11:56 AM   #4
ckhd
ckhd's Avatar
The 12-bolt rears have either an Eaton positracion unit or a GM positraction unit based on the Eaton. Both are friction disk limited slip units. That is what you have in the rear of your '68.
I don't know what they put in the Dana 44 in the front of your '68. I would bet it would be the same style. GM was pretty good about calling that type of limited slip differential a "positraction", and lockers something else (No SPIN, etc..).
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
