Buick Turbo 350 Tranny to SBC, How???
Picked up a turbo 350 tranny but its from a buick and they are shaped differently from a GM turbo 350 how can i mount this up???
Adapter plate? How can i order one??
72 GMC SB Built 400 SBC B&M TH350 12Bolt Posi 4:11 Bagged |
Where's my beer?
Re: Buick Turbo 350 Tranny to SBC, How???
I know there are adapater plates made to adapt a chevy bolt pattern trans to a BOP pattern block, so I assume it would work the other way too. I think the company is TransDapt if I remember right.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
Thanks..., Actually found one from speedwaymotors its only $39 --- and can be used BOP to GM or GM To BOP
72 GMC SB Built 400 SBC B&M TH350 12Bolt Posi 4:11 Bagged Last edited by Baged72; 12-02-2010 at 10:19 PM. |
I ran a Buick trans in 1 or mine old 72 gmc and it bolted right up I just left out the top bolt cause the buick had the notch up top. It worked good never had a problem. Just a little insite thought it might help
Posted via Mobile Device |
I think some of the trannies had both bolt patterns and some didn't. I had a T350 once that had both, and I've got a 200 4R that has both. But I think I've seen some that only had the top ears for the Buick and not the top Chevy holes.
If you don't have all the holes in the trans to match the engine, definitely get the adaptor. Last edited by arkansas; 12-03-2010 at 11:57 AM. |
an adapter plate can be used
There are a lot of people that ran a Chevy trans bolted to a BOP motor or vise-versa with just 4 bolts in them back in the day. It's only the top 2 bolts that are different. The bottom 4 are the same. There were some cases made with both patterns. That adapter may also require spacers for the converter or flywheel depending on how thick it is.
Just did the BOP Trans to Chevy block. Adapter plate from Speedway; comes with the hardware $47.53 shipped.
Only the bottom two bolts and the dowel pins are common between BOP and Chevy. Nothing else lines up unless you have a dual pattern bellhousing.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
#10 | |
http://community.webshots.com/user/hotrodhorn |
#11 | |
Correct, the bottom 4 are the same, it's only the top 2 that are different. I have seen it done, but I wouldn't run one like that myself.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#12 | |
