Old 12-02-2010, 10:46 PM   #1
19724x4plowboy
19724x4plowboy's Avatar
Dash lights and turn signal issues
My driver side turn signal light, on my dash cluster, is always half lit up when the lights are on. But all lights are working, front and rear. Except rear driver side marker. I haven't looked at it to see if it's a bulb or not. Wasn't sure if the cluster even cared if it worked or not. My problem is the turn signal doesn't work all the time when applied to make a "left" turn. Didn't know if I have a bad ground issue somewhere or just a bad turn signal switch. This is my second column and it is the doing the same as the previous column also.
Any ideas ??? What am I missing???
19724x4plowboy is offline   Reply With Quote
Old 12-03-2010, 01:58 AM   #2
roger0080
Re: Dash lights and turn signal issues
It's a bad ground problem. Clean the contact areas on the front parking lights and the rear brake light housings. I have one where I have to run a ground wire to the front left turn signal housing to get it to work.
72 Chev C-10 90% restored (former AZ truck) ...
71 Chev K-20 Cheyenne my vacation crusier...
72 Chev C-10 Now retired and striped after many faithful miles...
72 GMC 1500 Retired to the junk yard after bought new in '71...
roger0080 is offline   Reply With Quote
