Old 12-02-2010, 11:52 PM   #1
too the max
another 4/6 drop question fron a newbie
I just got a '70 c10 and can't stand the stance, so i want to lower it as much as I can without a c-notch and without replacing spindles. Can i get a 4/6 or 3/5 springs and accomplish this. Thanks!
too the max is offline   Reply With Quote
Old 12-03-2010, 12:10 AM   #2
BP68
BP68's Avatar
Re: another 4/6 drop question fron a newbie
Yes. Most stuff I have read says anything lower than 6" in the rear requires a notch.
I have the ECE 4/6 drop on mine (check out build thread) That is with springs AND spindles in the front.
I have yet to really drive it on the road much, but everything clears fine and others on here are running the same drop without issues.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 12-03-2010, 12:22 AM   #3
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Go ECE and you'll be fine with a 4/6, no notch unless you pull a trailer or a load of gravel.
Zoomin is offline   Reply With Quote
Old 12-03-2010, 01:43 AM   #4
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
some have gotten away with 5/7 with no notch, but I think that is pushing it. 4/6 should be fine.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 12-03-2010, 01:44 AM   #5
Jacfourteen
Very true, unless you cheat and put in helper bags
Old 12-03-2010, 06:29 PM   #6
Jack_71C10
Shortbed club member
Jack_71C10's Avatar
You wont be able to go 4/6 with just springs.
A 3/5 is better, but 3" front drop springs may dislodge when you're front
suspension sags. And with a 5" rear drop your shocks will be worthless
if not relocated. Your rearend will be offcenter (nothing personal) unless
you add an adjustable panhard bar.
You'll be better off going with a 2/4 if your just using springs.
71 custom/10 6.0/4L80E SWB ece 4/6
72 custom camper 350/3 spd
2020 Chevy Express 3500
2023 Hyundai Tuscon
1986 GMC 3500 Bucket Truck
Sent from my Rotary Phone via 14.4kb/s modem.
Jack_71C10 is offline   Reply With Quote
Old 12-03-2010, 06:40 PM   #7
Cole Trickle
C-10 Club Member
Cole Trickle's Avatar
no isues driving with my ECE 4.5/6 truck (All new shocks springs relocators and spindles)
Handles good and I never hit the rear axel on a recent 600 mile road trip. I did scrub the tires on the inner fenders on a nasty freeway dip but it was no biggie.
Perfect drop for a driver imo.
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels
1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold
Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910
Cole Trickle is offline   Reply With Quote
Old 12-03-2010, 10:31 PM   #8
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Take a look at Cole Trickle's or my build thread to see the complete install of the 4.5/6" drop kit available from ECE; it's the only way I would go.
Click on Project Blank Slate below...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-04-2010, 12:13 AM   #9
70jnktrk
70jnktrk's Avatar
4/5 1/2 spindles and springs...all ECE.....as mentioned no notch is necessary
70jnktrk is offline   Reply With Quote
