12-03-2010, 10:00 AM | #1 |
2004r tranny or 7004r ?
Hi I have been looking for a 2004r transmission for the last 2 weeks and have not found one but found a few 7004rs. my question is there is a trans out of a 84 corvet with less of 20k rebuild he says is a 700 he wants 250 ,should I get this one or look for an other?
Posted via Mobile Device |
12-03-2010, 10:31 AM | #2 |
Its a Truck Thing......
Re: 2004r tranny or 7004r ?
200 has a better first gear, that is a good price for a 700, if you really want a 200 get it.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
12-03-2010, 10:54 AM | #3 |
200's are hard to find, nothing wrong with the 700. go for it.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
12-03-2010, 10:55 AM | #4 |
from what i've seen the 200 is more tolerant with the TV cable adjustment
12-03-2010, 04:30 PM | #5 |
Ok so beside cutting the drive shaft do I need the yoke? Or the one on my th350 will work?
12-03-2010, 05:13 PM | #6 |
Cops, ha, catch me if you can!
I assume you want to get a used 2004r, if that’s the case I don't think you'll be happy with a used one. Depending on the power of your truck it may not last. You can get a new/rebuilt 2004r that is built to handle a lot of power, say like 400hp+ for about $1400, I think I saw that one from Bow Tie Transmissions. If you don’t want to spend that much, I say go with the 700r4 or wait till the funds are available for a 2004r.
72 C-10 Stepper 350/TH350 3.73 in the back Edelbrock intake and Carb Hooker Comp Headers 275/60R15 on Rallies |
12-03-2010, 05:17 PM | #7 |
Nice thing about the 200r4 is that it is the same overall length as the th350 (depending on 350 tailshaft, 6" or 9")....can't remember which. You'll have to move tranny mount a little. You might get lucky and not have to dick with your driveshaft....yokes should be the same.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
12-03-2010, 05:33 PM | #8 |
The engine is a 292 6 cyl. I'm just looking for crusing @ 70 mph on the freeway. Right now @ 60 mph sounds like the engine is going too fast
12-04-2010, 11:39 AM | #9 |
Cruising at 60, I am going to guess that you are turning almost 2900RPM. (depending on what size tire you have). Making the swap to a 2004r would drop your RPM down to 1950 and with a 700r4 it would be down to 2050, those numbers are for 60mph. If you don't plan on upgrading your engine any time soon, I say keep on looking for a used 2004r.
12-04-2010, 11:48 AM | #10 | |
Old Skool Club
If it is going behind a 6-cylinder, go for it.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
12-04-2010, 12:59 PM | #11 |
Msgt USAF Ret
When I bought my 67 it had a 700r4 in it and the drive shaft was cut 3 inches. The truck was originally a six cylinder with a standard shift. I'm not sure what trans came in it. I had the 700r4 front pump rebuilt because it was leaking, and in the process of that the shop told me that the trans would need rebuilding before long. They also told me the torque converter input shaft bearing was in bad shape.
I had access to a rebuilt th350 from the PO of my truck so I decided to use that along with the torque converter for it. He also gave me the drive shaft for the truck but I think that drive shaft is for the original six cyl. standard because it is shorter than the 700r4 shaft, which is shorter than the v-8 TH 350 combo by 3 inches. The point of all this is, the six cylinder drive shaft may have to be lengthened to run the 700r4 or the 2004r if it came with the standard trans and was converted to an automatic. Hopefully someone has the drive shaft dimensions for a v-8 with the th 350 with the engine in the forward location. I am posting this to let the sixers know what they might have to do if they want to run a six/350/700r or 200r4 combination. Also I would like to know what length drive shaft I am going to need for my v-8 th350 combo in the fwd position. It should be a stock length and I wonder if any of the 80/90 years will fit. I read someplace that the corvette ODs were not desirable for some reason for our trucks and if I can find it I'll post the link.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
12-04-2010, 01:08 PM | #12 |
250 6 cyl-three speed standard shift changed to 2004-r, no change or mods to drive shaft. Best mod you'll ever make.
12-04-2010, 01:29 PM | #13 |
I made up my mind I'm gonna keep searching for a 2004r since this no my d/driver
12-04-2010, 04:14 PM | #14 |
3 speed manual, "short" TH350, and 200-4R are all the same length (about 27" overall - include the bellhousing on the manual). The 700-R4 is about 3"
longer. Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
12-04-2010, 06:14 PM | #15 |
where r u that you can't find 200r4's
12-04-2010, 06:52 PM | #16 |
I'm in Sacramento ca. I went to pick n pull today n found 3 on 87 86 cutlass and one was already off so I got that one n I'm gonna clean it up n try it. if it's not good I know a guy who will rebuild it for 250 plus parts. thanks everybody
12-04-2010, 07:41 PM | #17 |
let us know how it works.......You have a good OD auto and it can be built for serious HP.
12-04-2010, 09:56 PM | #18 |
if i had a truck with a th350, i'd find me a 200-4r because it a nearly 100% bolt in upgrade. the 700-r4 has a more aggressive first gear and the 200 has a slightly better overdrive ratio. they both have their supposed durability issues (when compared to the 3 speed autos) but they are plenty stout for everyday use and there are some aftermarket upgrades/builders that will make them plenty beefy for just about any street application. also consider such things as running a lockup converter and using synthetic fluid to reduce heat related wear.
in these modern times of environmental awareness and steep gas prices, having an overdrive for long distance / high speed driving is the logical choice, especially when GM makes upgrading easy. heck, on my 72 burb c20 i swapped the rear axle from a 4.57 to 4.10 third member and have a 66-69 borg warner overdrive equipped saginaw trans so i can keep three on the tree. |
12-05-2010, 12:33 AM | #19 |
just found this on craigs list im not familiar with this company just thought id pass it along
SUPER BUILT REBUILT CHEVY 200R4 W SHIFT KIT/WARRANTY - $499 (SUPER SHOPS 714-758-5249) -------------------------------------------------------------------------------- Date: 2010-12-02, 10:07AM PST Reply to: sale-wacwb-2091235415@craigslist.org [Errors when replying to ads?] -------------------------------------------------------------------------------- SUPER BUILT REBUILT CHEVY 200R4 W SHIFT KIT/WARRANTY $499.99 IN STOCK SUPER SHOPS 619-562-4339 WWW.SUPER SHOPS.COM INCLUDED 1 YEAR WARRANTY 12 MILES SHIFT KIT PERFORMANCE REBUILD •Location: SUPER SHOPS 714-758-5249 •it's NOT ok to contact this poster with services or other commercial interests PostingID: 2091235415 --------------------------------------------------------------------------------
1990 chevy 4x4 with a 1940 IHC body |
12-05-2010, 12:37 AM | #20 |
here's another.......hope this is ok to post like this if not ill redow/just the posting #
Transmissions Rebuilt T-200R4 multi case patern fit all GM motors Warr - $700 (pierce,king,thurs.all counties) -------------------------------------------------------------------------------- Date: 2010-11-30, 2:03PM PST Reply to: sale-yzu92-2087978965@craigslist.org [Errors when replying to ads?] -------------------------------------------------------------------------------- I can fully Rebuild you a T-200R4 Transmission With a full Box Kit.All new Gaskets Clutches Bands,Pump bushing and all Bushings needed for this unit.I can install my own built in Shift Kit,which will give this a good firm Shifts,or we can install a good Street Rod Shift Kit. Can Get You A stock Torqe Converter or a Corvette 2000 Stall Converter your choice.Extra cost. This T-200R4 Transmission Has Multi Case Pattern it will fit your Chevy,Olsmobile,Pontiac,Buick to replace your T-350 or T-400 , T-200 Three Speed Transmission.The T-200R4 is a overdrive 4 Speed automatic with a lock up torqe converter. This will give your type car better Freeway Driving Gas Milage.THESE UNITS HAVE BEEN KNOWN TO BE USED IN THE Grand Nationals,Built Right They will Hold Up. Installation is Available/Lots Of Refereces 30 yrs exp. 17 yrs in own Business Warrantys Available 1Yr,2&3 yr & a Lifetime Limited Warranty Cal Bob 7 Days A Week Until 11 pm For All Details 253-273-3860 360-458-1385 •Location: pierce,king,thurs.all counties •it's NOT ok to contact this poster with services or other commercial interests PostingID: 2087978965
12-11-2010, 11:11 AM | #21 |
I found an other trans with code BQ I think is GN rebuilt with 1 year warranty I'm gonna be put today. What oil do you guys use so I can go get it now. I'm gonna replace today thanks
12-11-2010, 05:24 PM | #22 |
i like to use synthetic fluids. automatic transmissions make a LOT of heat (especially when towing) and that wears them out that much faster, so get a good quality atf fluid and don't neglect maintenance and you should be ok.
12-11-2010, 06:10 PM | #23 |
Ex-Minitrucker
2004rs are a multibolt bell housing so they were the base auto trans in most 80s GMs. They are in every rear wheel drive 80s Cadillac, Monte Carlo, Cutlass, Regal, and all Full size GMs and Wagons. Ive never had a problem finding one ever!
68 C10 LWB 292 4spd 68 C10 LWB 250 3spd |
12-16-2010, 05:56 PM | #24 |
Ok tranny is in. I let my cousin fill the tranny but he did not pay attention how many quarts he put in(I should have donnit my self) I fill the torque till it didn't leak when up. Now the level is about 1 1/2 inch past the full, I know is gonna take some fluid to fill up the torque con. I'm wondering if we put too much fluid. I haven't start the truck til I herd from what you guys think. Thanks again
12-16-2010, 10:23 PM | #25 |
Here kitty kitty kitty
I am watching to see how this turns out......
