Old 12-03-2010, 11:57 AM   #1
cajun chevy
cajun chevy's Avatar
dana rear end
I saw a dana posi rear end advertised for sale and was wondering if it would fit my 1972 c10 12 bolt.
These are the #'s posted in the add. do the mean anything
5-31-61-dana -18445-b3d347.12
cajun chevy is offline   Reply With Quote
Old 12-03-2010, 01:12 PM   #2
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: dana rear end
I don't know anything about the #'s, so my advice would be call and ask if what it came out of. If it came out of one of these trucks (Chev or GMC), find out if it is a coil or leaf and how many lugs the axles have. If it has the same specs as yours it will fit, if not it will require some modification to make it fit. If you have more detailed info it would help, because there are alot of Dana rears in many configurations. Also what is your truck, coil or leaf? Hope this gets you on the right track.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 12-03-2010, 01:57 PM   #3
ERASER5
ERASER5's Avatar
Re: dana rear end
X2! You need a low more info. And if you found a drop in replacement (like I did), you will still need to shorten the drive shaft and use a U joint the fits the Dana yoke on one side and the drive shaft yoke on the other.
I found a 3/4 drive shaft from a truck with an original D60 8 lug. I left the front section in place and removed the rear section from my truck and installed the "new" rear section from the 3/4 Ton. (Side one out, slide one in. Thanks Longhornman)) This got me matching U-joint sizes and almost the right length. I still need to cut about 3/4" out somewhere.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 12-03-2010, 02:20 PM   #4
Jacfourteen
Re: dana rear end
If you got the guy on the phone you prolly want to find out the ratio too.
