Truck will not start.
So I was doing a bit of welding today on my trailer, BUT I forgot to disconnect the light plug between the truck and trailer. Now the truck will not start, is it possible that I blew the fuseable links or any under dash fuses with feedback from the welder? I checked the battery voltage,its fine. I have not had a check to check for voltage at the starter. Issue is, it just clicks once when I turn the key. It is a year old Autozone starter that has hot start issues.
Any thoughts? A diagram so I can check the voltage at the starter later? |
Re: Truck will not start.
if it just clicks ,,,check your ground ..from batt. to frame ,, and frame to engine .......... autozone starter ,,,,,,,,, rebuilds sucks .... next time try a napa rebuild ........i never had good luck with autozone ..
When you get a chance, check the purple wire running to the starter for voltage. If you aren't getting full voltage, it may not be fully engaging the solenoid. I would post up the wiring diagrams, but my wife packed up all my books for our move.
Well I fixed the problem, It was something real simple that I should have checked, but I was a little stressed out from my finals and all. The ground cable was loose on the battery.
I do plan on the Ford remote solenoid install at some point, the hot start issue is real bad. |
#5 | |
the pollock
Ford solenoid?
nah . Buy a descent hi torque from napa and a heatshield. heat kills starters YES.. BUT! that's why you dont get a cheap autozone starter. you dont have to buy a jegs or summit super starter either. just a 80 dollar (with core) high torque starter with a heat shield. My headers are about half an inch from my starter. but put a good one and a shield on and the hot starts have not been an issue for over a year.
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
