Old 12-03-2010, 07:19 PM   #1
khp71
differential housing switch
could i switch my 71 chevy differential housing with leaf springs, with one from a 79 chevy? both trucks have 5 bolt wheels.
khp71 is offline   Reply With Quote
Old 12-03-2010, 08:04 PM   #2
cdowns
cdowns's Avatar
Re: differential housing switch
use a tapemeasure and see what the spacing is on the leaf mounting pads, also overall width
Old 12-03-2010, 09:11 PM   #3
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I think the spacing is a little narrower on the 79, I think the leaves are wider too. You could do it but prolly need to weld new saddles on.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 12-03-2010, 09:11 PM   #4
Jacfourteen
Oh and the shock mounts are different too.
Old 12-03-2010, 09:46 PM   #5
turp mcspray
turp mcspray's Avatar
Same width, different pad spacing, and shock mount location.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
