steering centerlink issue after swapping crossmember
I have a 62' c10 that I swapped a 72' front crossmember into a while back. I have been driving it for a while and on my trip up to Moultrie, GA. I noticed my steering wheel would hang up in the center position, which was quite annoying because it made me swerve left or right. The problem is my center link/relay rod is rubbing on the crossmember and causing it to hang. I am using the 62' centerlink.
Has anyone else had a similar issue or if you have the same swap what centerlink are you using? I had a 72' laying around but I lost it in my last move. Thanks for you help in advance.
1984 C10 swb 1985 K20 longbed 4spd 1977 K10 longbed -SOLD 1962 Chevrolet C10 swb 6cyl. 3spd. -SOLD |
Re: steering centerlink issue after swapping crossmember
I forgot to add that I am also using the 62' idler arm. Hope that doesnt make a difference.
Truck and auto performance nut
what about the pitman arm?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
![]() Join Date: Aug 2009
I used all parts from a 72 on mine, do you by chance have the center link reversed?? or backwards? the nuts for the steering arms should face the front of the truck
You didn't mention if you had power steering. I did the k member swap on mine and the idler arm had to be moved forward a little to maintain the correct geometry. I used an 83 model
'66 C20 converted to C10, 454/TH400 '66 C10 saved from crusher ![]() |
Senior Enthusiast
I have a 1960 with a 1975 crossmember, but I used all the 1975 steering linkage including the idler arm. I had done a power steering upgrade years earlier using the REZ kit and have never had any clearance issues.
Are you using the original 1962 manual steering box, or a later power box? And where is the center link rubbing against the crossmember. Is it somewhere on the bar, or the adjuster links? Also – did you move the crossmember forward to better center the wheels in the wheel wells, or is it in the stock location? |
#7 | |
The pitman arm and steering box are the original 62'
Its not on backwards.
Should I swap 72' steering centerlink, idler arm and pitman arm as well to make it not rub?
#9 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Do you have any pics of your front suspension? Also,... what year inner and outer tie rods did you use?
I dont have any pictures of it right now. Im pretty sure I ordered 72 inner and outter tierod ends. I went crazy on LMC and had to order certain things for a 62 and other stuff for a 72, but im pretty sure they are 72.
I'm not sure the 72 inners will work with the 62 centerlink.
Inners are sold as 60-62, 63-64, 65-70, and 71-72. Like said above by another member,... you may need to move the idler arm and pitman arm. Take some pics if you can.
mine had this problem after I changed pitman arms. I got it corrected tho the pitman arm does need to go farther on the output shaft, it just won't. Now the truck has new tie rods and the outers have an angle to them the originals didn't. Provided more room for the center link to clear the crossmember.
these are Moog parts btw... ![]() ![]()
#13 |
Those outters look bent.
Got any picks of the inners connected to the center link? Posted via Mobile Device
#14 |
outers came that way from Moog. no inner pics...but I can take some if you like....they're staight.
