Old 12-03-2010, 08:41 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
HEI heat soak
Lately, after I have driven my truck for a day and have had multiple starts, the truck will just turn over and not start (or sound like its even getting spark). I have a timing light on me and i put it on to check for spark. The light doesnt flash. I had a can of starter spray and I sprayed it on the exposed coil to cool it of. It started right up. Why is my coil getting so hot? Does anyone have a wire diagram from the coil to the fuse box. Im thinking about running a new wire to the coil.
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 12-03-2010, 08:47 PM   #2
coloradosean2009
coloradosean2009's Avatar
Re: HEI heat soak
Improper wiring to an HEI is a common problem. Not sure if that would cause the coil to run hot though.
Have you recently made any changes to the electrical system?
__________________________________________
Sean
1972 C20
2005 4Runner
coloradosean2009 is offline   Reply With Quote
Old 12-04-2010, 04:57 AM   #3
crm318
crm318's Avatar
Re: HEI heat soak
The system has been the same and untouched for 7 years. The coil is only 3 months old and the other coil was doing the same thing, which is why I swapped them. I just thought resistance in the wire might cause it to heat up.
1972 Cheyenne
Old 12-04-2010, 11:06 AM   #4
coloradosean2009
Re: HEI heat soak
I would start with the feed. Good instructions in the Electrical subforum FAQ
Sean
1972 C20
2005 4Runner
Old 12-04-2010, 12:13 PM   #5
Lee H
Lee H's Avatar
Re: HEI heat soak
Are you using quality parts? Not unheard of to get a few bad parts. Check that your getting a full 12Vs to the coil.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 12-04-2010, 01:41 PM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: HEI heat soak
You may need one of these or you may have your insulator in wrong.
http://www.summitracing.com/parts/MS...5&autoview=sku
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 12-04-2010, 08:15 PM   #7
crm318
crm318's Avatar
Re: HEI heat soak
What is my insulator? I removed the ceramic piece when I converted from points (assuming that is what your refering to).
1972 Cheyenne
Old 12-05-2010, 12:58 AM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: HEI heat soak
It's the rubber washer in the center. The other part with the spring is the one I gave you the link to. You might want to consider just buying a new cap.
VetteVet
Old 12-05-2010, 11:22 PM   #9
crm318
crm318's Avatar
Re: HEI heat soak
Vette Vet, im pretty sure that I have the graphite button piece under the rubber insulator.
1972 Cheyenne
Old 12-06-2010, 12:12 AM   #10
OhOneWS6
OhOneWS6's Avatar
Re: HEI heat soak
I am pretty sure Vette Vet's picture is incorrect. The carbon button goes in first, then the insulator, then the coil.
OhOneWS6 is offline   Reply With Quote
Old 12-06-2010, 12:44 AM   #11
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: HEI heat soak
I posted the picture from board member Shifty's FAQ to show CRM what the insulator looks like. The carbon button has to go through first to touch the rotor. If the picture is wrong then the button won't be through the cap far enough to hit the rotor and the motor won't get spark.If you're saying that the rubber insulator goes over the spring mount then you may be right. Looking up inside the cap at the carbon button would show which way is correct.
This shows the button so it should be easy to figure out how it goes.There may be a recess under the washer in the cap for the spring mount to to fit in. It's been awhile since I had one apart. I've got 3 or 4 out in the garage so I'll go look tomorrow.
VetteVet
Old 12-06-2010, 09:11 AM   #12
coloradosean2009
Re: HEI heat soak
I agree, picture is wrong.
Sean
1972 C20
2005 4Runner
