12-04-2010, 12:21 AM | #1 |
Factory Strippers Rule!
14" wide Rims?
In the new StreetTrucks mag, there is a '71 Chevy running some 24x14 rims with 405 rear tires. Can these tires and rims fit without narrowing the frame and/or rearend? They look good, but not if they are a PITA to put under there. Any insight?
"Feast your eyes on a feast of smoke." 67 Chevy Short Fleet PLAN: LQ9, 4L60, D60 Looking for School Bus Gauges - Help me out! |
12-04-2010, 12:25 AM | #2 |
Re: 14" wide Rims?
No you have to narrow it. I haven't seen a pic but Extensive built a 50's Ford on 24x14's and it looked sweet!!! I like the narrow wheel look so I dont search a lot of that look lol.
Posted via Mobile Device |
12-04-2010, 12:28 AM | #3 |
Happy to be here
Re: 14" wide Rims?
You can run a 12" wide wheel with stock rails, but 14" is pushing it. If the 14" wheel does fit with stock rails, you will need to narrow the axle.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 12-04-2010 at 08:17 PM. |
12-04-2010, 12:44 AM | #4 |
Re: 14" wide Rims?
im running 14inch rims on mine. just took 14" out of the rearend. frame is stock width
12-04-2010, 01:13 AM | #5 |
Re: 14" wide Rims?
WOW! Those tires are wide.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
12-04-2010, 01:19 AM | #6 |
Big Red - Now its a SWB!
Re: 14" wide Rims?
It can be done without cutting anything but the wheelwells and bed, but it requires a custom backspaced rim. ProstreetC-10 did it on his truck, read post #54 in this thread.
http://67-72chevytrucks.com/vboard/s...=322819&page=3
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
12-04-2010, 05:33 PM | #7 |
Re: 14" wide Rims?
Thanks for the thread link! So from the looks of it, with the bed floor cut to the frame width they will physically fit in there. So, is there a reason WHY the rearend would have to be narrowed or is it just for the deep rim look? I would think if the rim was centered over the axle flange it would be fine, but maybe I am overlooking something...
12-04-2010, 07:22 PM | #8 |
Re: 14" wide Rims?
did it with my 71.... 15x14 w/ 10" back spaceing 31x18.5x15 ... bed was tubbed to frame .. fit was perfect.... only problem i had was no way to balance them with the 10" BS.. wouldnt fit on any tire machine.. i could have bubble balanced them but no one had a bubble balance...
