230 inline 6 to a 400 sbc...give it to me straight
was just wanting to know exactly what i will need to do to go from a 250 inline to a 400 sbc...i am about to start this project and i know i can rely on you guys on here...please give it to me straight....motor mounts??? i plan on using a 400 turbo tranny..short shaft....will i need to relocate the rear tranny mount???
thanks for all your help!!!!
![]() Join Date: Nov 2009
Re: 230 inline 6 to a 400 sbc...give it to me straight
I'm currently in the process of doing the same on my 69SWB but with a 350. engine mounts and their location can remain the same. The wiring will need to be modified if you were not running and HEI on the 250. Also, on my 250, the alternator was on the drivers side and for the 350, it was on the pass. side. Radiator Hoses will need to be changed along with the radiator and fan shroud. I'm not sure on your T400 as I kept the 3speed so I didn't have to modify from the tranny back.
#3 | |
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
Junior Member
My son is running a 3 speed muncie behind a slightly modified 454 with a posi without a problem. He is not real easy on it either.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
#5 | |
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. Last edited by raycow; 12-04-2010 at 04:27 PM. |
hey ray...thanks for the info...my truck currently has a four speed manual tranny.....
Big Red - Now its a SWB!
If you're trading out the tranny too you might as well move the engine to the forward holes and use the small block towers. Like stated above you will need to get rid of the crossmember your bell housing is mounted to now and get a auto tranny crossmember. You will have to run the auto linkage and shifter and you can just seal up the hole where your shifter is now or you could even change to a low hump floor. Exhaust will have to be addressed, when I changed mine I just scrapped the stock pipes and had a shop run all new dual exhaust. also you will need to find a different driveshaft or get yours modified. Hope this helps you out.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
hey guys,
i can use all the help i can get...i wasnt sure of the engins mount location..ive heard many different views on were they should be..i guess i should just dive in and then my questions can be asked as i go....thank you all again for your help...i can always rely on this site for help
#9 | |
Here is what the small block v8 stand looks like, it's the one on the right with the small hole in it (if you are wondering the other one with big hole is for v6).
![]() These are the mounts that you need for the small block. Here is a link for them, they cost $7 per side, http://www.autozone.com/autozone/par...3627_195313_0_ Hope this helps you out.
