Old 12-04-2010, 02:40 PM   #1
cam.man67
cam.man67's Avatar
does anybody sell...
...a full exhaust system, with pipes to take the exhaust out past the rear tires? I'm getting tired of huffing exhaust fumes and having the mufflers drone under the cab as it is now. I'm thinking something along the lines of a direct replacement to the original system.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline   Reply With Quote
Old 12-04-2010, 02:50 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: does anybody sell...
LMC all day long....
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 12-04-2010, 03:12 PM   #3
C. M. Wolf
C. M. Wolf's Avatar
Ditto on LMC...
And they also sell the Magnaflow "Stainless Steel" tube sets,(which is what I'm now switching all my vehicle exausts to... the Stainless Steel tubes, I mean). AL-ized-steel is all well and good, but the AL burns off where ever the tube is welded together. Stainless Steel pipe lasts way longer than AL/Steel pipes, IMHO, that makes it worth the added cost,(that and I can weld stainless myself).
I didn't go with the Magnaflow pipes, myself, because I didn't like the placement/design of the system. I basically cut, bent, and fit my own tubes exactly where I wanted them instead, that and I am running a custom-built set of headers on my 70-C20 that I needed to start from. (I'm also real hard to please, so I have to ask folk's pardon at times... ).
I still insist that I'm not the only American in this country that hates the "Kirby-Vacume-Cleaner Sound" coming from my exaust as I drive down the road! But on the other hand I shudder at the thought of "All Noise and Little Movement" too! (...all those special gears I have on/in my engine were expensive enough to want to hear too).
Michael
C. M. Wolf is offline   Reply With Quote
Old 12-04-2010, 06:43 PM   #4
cam.man67
cam.man67's Avatar
I see the glasspack kit on LMC..has anybody used that before? Also, I'm running headers, what kind of cutting/fab work am I going to have to do to get this setup to fit up right?
Old 12-04-2010, 07:54 PM   #5
rsavage
rsavage's Avatar
Summit sells a dual aluminized mandrel bent set up made by Hooker Headers for about $200 with a choice of rear exits straight out the back or behind each wheel. You have to buy mufflers. I used cherry bomb turbo mufflers. It was a decent kit that fit pretty well ( a couple of the slip joints were a little too tight and I had to expand them). It had all the hangars, clamps, etc. Total was about $260 with mufflers.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 12-05-2010, 09:39 AM   #6
cam.man67
cam.man67's Avatar
So it comes with both types of exits?. I'm definitely going with side exit, but the rear exit might be a nice change later on.
Old 12-05-2010, 11:24 AM   #7
rsavage
rsavage's Avatar
No. I thought I had a choice when I ordered it but in checking today it appears only side exits. Part number at Summit is 16621HKR if this link doesn't work:
http://www.summitracing.com/parts/HO...n/?prefilter=0
1961 C1 Corvette
2021 Durango RT 5.7
Old 12-05-2010, 11:30 AM   #8
Ol'Rover
Project: years too late.
Ol'Rover's Avatar
Magnaflow LMC we just got ours we are trying to put it into its place on our 71 C10 at the moment.
1971 C10 Stepper LSX 5.3/4L60E 3.73 12bolt posi. Father Son Project. In Memory of Bruce C. Shorten. Rest easy Dad. Ill take it fryom here.
Ol'Rover is offline   Reply With Quote
Old 12-05-2010, 12:07 PM   #9
Spoof
Spoof's Avatar
I just picked up the Magnaflow set-up, it looks great in the box, comes with all the hangers, rubber, clamps, mufflers etc. It even came with an extra crossflow chamber! ( accidentally I assume, see my earlier post)
Cost $599 Cdn, not cheap but easy to order from most exhaust shops so no shipping hassles.
I expect some work will still be required to hook the exhaust up to my sanderson headers, I'll get someone who knows their stuff for that.
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 12-05-2010, 12:22 PM   #10
Ol'Rover
Ol'Rover's Avatar
i saw the 2 xpipes you got!
we got the same kit, but we are having some difficulties since our truck is a shortbed with LT headers , and its a universal kit made for a LWB. we picked ours up through bensons for 435.87cdn. I cant wait to hear it fire with the kit on!
Old 12-05-2010, 12:30 PM   #11
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Post pictures, I'd like to see where the x ends up being. You think the pipes they give you could hook into a stock rams horn?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 12-05-2010, 12:34 PM   #12
cam.man67
cam.man67's Avatar
That appears to be a manifold-back exhaust system. The one I found of Summit is this:
http://www.summitracing.com/parts/HOK-16522HKR/
..which is their so-called header-back exhaust system. I'm just trying to figure out why there's a $30 diff, that's all.
Old 12-05-2010, 07:07 PM   #13
rsavage
rsavage's Avatar
The difference is that header back system isn't going to connect to stock exhaust manifolds; the front pipes will connect at the header collectors.
1961 C1 Corvette
2021 Durango RT 5.7
