Old 12-04-2010, 11:57 PM   #1
Indyuke
Very productive day... (pic heavy)
Been meaning to take care of some truck love lately, so this week I was able to pull it in and rebuild the front end and do some rust prevention on the bottom of the doors. I kinda got carried away and spruced up both doors rather than just limiting myself to the bottoms.
I'll post some more pics once I get everything back together.
Replaced every moving part on the front end, including the brake hoses.
Decided to redo the steering wheel and paint the guages.
A while back I found some pristine door panels at pull a part, so I snagged them, painted them and put some of that sound dampener stuff on the back.
Indyuke is offline   Reply With Quote
Old 12-05-2010, 12:00 AM   #2
FL71C10
Re: Very productive day... (pic heavy)
Looks good, what kind of suspension parts did you use?
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 12-05-2010, 12:01 AM   #3
69Beauty
69Beauty's Avatar
where did you get the frontend rebuild parts at?
1969 C-10 LWB 388 SBC Vortec Heads 10:1 Lunati 60103 cam Weiand intake Quadrajet Carb 12 Bolt 3:73 posi 700r4 Hedman Headers
1998 Dodge Ram 1500 Reg. Cab Long Box 4X4 5.9L 183k miles
1956 Ford F-100 Longbed with Original 272 and 3OTT
1995 C1500 ECSB 6.5 Diesel 4l80e (Camper puller)
1997 Dodge 3/4 ECLB V10 (MPG machine)
69Beauty is offline   Reply With Quote
Old 12-05-2010, 12:04 AM   #4
Critter
Future TOTM Winner
Critter's Avatar
I'm ready to see how this turns out...seems pretty cool!
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 12-05-2010, 12:20 AM   #5
VA72C10
VA72C10
VA72C10's Avatar
very nice!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 12-05-2010, 12:22 AM   #6
NORMSCOLORADO
NORMSCOLORADO's Avatar
very nice!!!
04 Chevy Colorado Z71 4X4
76 Chevy C-10 Custom Deluxe (sold)
67 Chevy C-30 1 Ton 9' stepper 6.5 Turbo Diesel
NORMSCOLORADO is offline   Reply With Quote
Old 12-05-2010, 12:29 AM   #7
hayhauler71
hayhauler71's Avatar
You said it Very productive day and all looks very nice
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 12-05-2010, 01:20 AM   #8
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Nice work man.
--Josh
Old 12-05-2010, 02:35 AM   #9
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Looks good, did you get the cluster back together? I'd like to see how it looks painted green.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 12-06-2010, 04:54 PM   #10
Indyuke
Here are the completed pics. The gauges turned out a little darker than I thought they would... almost black. But when the sun hits it you can see the contrast and it looks good.
Old 12-06-2010, 05:25 PM   #11
cable666guy
cable666guy's Avatar
Wasn't really digging the in-progress paint pics, but wow does that look nice!!
cable666guy is offline   Reply With Quote
Old 12-06-2010, 07:16 PM   #12
Indyuke
Thanks for the compliments. For the front end parts, I just went down to the local 0'reilly's. Mostly McQuay Norris and some Master Pro stuff. Drove the truck to work today and it rides fine. The biggest difference? I sure feel the authority of the new springs and sway bar bushings. =) I don't hear anymore popping of bad ball joints either.
I've got a little bit more adjusting to do with the alignment to do yet, but it's definately an improvement.
Old 12-06-2010, 08:07 PM   #13
VA72C10
VA72C10
VA72C10's Avatar
very nice!
Old 12-06-2010, 09:31 PM   #14
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-06-2010, 10:39 PM   #15
swamp rat
swamp rat's Avatar
I do like the dark green in the guages!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
